[mapserver-users] gdal bigtiff support
Travis Kirstine
traviskirstine at gmail.com
Thu Nov 17 16:03:35 EST 2011
It turns out to be a user error, I had updated mapserver but failed to
update the cgi wrapper script for the WMS.
Thanks
On 17 November 2011 15:35, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On Thu, Nov 17, 2011 at 12:15 PM, Travis Kirstine
> <traviskirstine at gmail.com> wrote:
>> I have created some tiled BigTiffs (6 GB) with gdal 1.8 with the
>> internal tif lib. I keep getting a "msDrawRaster(): Image handling
>> error. Unrecognized or unsupported image format
>> drawEPP(): Image handling error. EPPL7 support is not available" when
>> attempting render the the image with Mapserver 5.6.7 (w/ gdal 1.8). I
>> have also noticed that some of my non bigtiff tiled geotiffs are
>> rendering with missing tiles and or in strange colours. I can access
>> the files with gdal without a issue. Is there something I'm missing?
> Travis,
> Are you using full paths to the files in question. I vaguely suspect
> that the fopen()s used in path construction within MapServer do
> not work properly with large files (>4GB). If that turns out to be
> the issue please file a ticket on it.
> The work around would be to use a full path instead of depending
> on SHAPEPATH or map relative path construction.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
