[mapserver-users] layerObj queryByPoint problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Nov 24 05:35:51 EST 2011
I cannot say anything about your problem, but your MAP extent looks a bit off to me. Do you really want to be closed into a 360 by 360 metre box around the (0,0) point at the equator?
-Jukka Rahkonen-
kirill bogdanov wrote:
> Hi, i have a problem with queryByPoint as well as queryByRect
> in layer class
> - they always return MS_FAILURE also as in mapObj class.
> I am coding in c# for desktop not for web.
> And I have a template in class of layer. Here is my files:
> map file
> MAP
> EXTENT -180 -183.1126335 180 176.8873665
> FONTSET "../fonts/fonts.list"
> IMAGECOLOR 255 255 255
> IMAGETYPE "png24"
> NAME "MS"
> SHAPEPATH "../data"
> SIZE 1024 1024
> STATUS ON
> SYMBOLSET "../symbols/symbols35.sym"
> TRANSPARENT TRUE
> UNITS METERS
> OUTPUTFORMAT
> NAME "png24"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE RGBA
> TRANSPARENT TRUE
> END # OUTPUTFORMAT
> PROJECTION
> "proj=merc"
> "lon_0=0"
> "lat_ts=0"
> "x_0=0"
> "y_0=0"
> "a=6378137"
> "b=6378137"
> "units=m"
> "no_defs"
> END # PROJECTION
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> COLOR 0 0 0
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> STATUS OFF
> END # LEGEND
> QUERYMAP
> COLOR 255 255 0
> SIZE -1 -1
> STATUS OFF
> STYLE HILITE
> END # QUERYMAP
> SCALEBAR
> COLOR 0 0 0
> INTERVALS 4
> LABEL
> SIZE MEDIUM
> COLOR 0 0 0
> OFFSET 0 0
> SHADOWSIZE 1 1
> TYPE BITMAP
> END # LABEL
> SIZE 200 3
> STATUS OFF
> UNITS MILES
> END # SCALEBAR
> WEB
> END # WEB
> LAYER
> DATA
> "\\factinf\filestorage\dc4e2278-8b12-4b80-a6dc-742ce774d1aa\world"
> EXTENT -180 -89.9 180 83.674733
> NAME "\\factinf\filestorage\dc4e2278-8b12-4b80-a6dc-742ce774d1aa"
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END # PROJECTION
> STATUS ON
> TILEITEM "location"
> TOLERANCE 100
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "The World"
> STYLE
> ANGLE 0
> COLOR 0 0 0
> OFFSET 0 0
> END # STYLE
> TEMPLATE "c:\ms4w\apps\tutorial\htdocs\template.html"
> END # CLASS
> FEATURE
> POINTS
> -92.22255 14.519233
> -92.1567 14.619833
> -92.1863 14.808033
> -92.111 15.0177
> -92.1379 15.0876
> -92.1567 15.105533
> -92.2347 15.123467
> -92.28845 15.170067
> -92.2427 15.268633
> -92.0787 15.5052
> -91.8905 15.7633
> -91.6862 16.075133
> -91.62435 16.0823
> -91.33665 16.073367
> -90.70745 16.084133
> -90.4977 16.082333
> -90.46545 16.098467
> -90.45735 16.188067
> -90.39285 16.290233
> -90.3794 16.3655
> -90.3794 16.395967
> -90.41975 16.421067
> -90.6617 16.5089
> -90.6913 16.535767
> -90.7128 16.655867
> -90.77735 16.720367
> -90.89565 16.790267
> -91.11075 16.865533
> -91.20755 16.9193
> -91.36345 17.112867
> -91.36345 17.1469
> -91.33925 17.166633
> -91.25325 17.180967
> -90.9467 17.209633
> -90.9494 17.499967
> -90.96825 17.7455
> -90.9521 17.774167
> -90.91985 17.783133
> -90.39555 17.772367
> -89.76365 17.758033
> -89.2017 17.7688
> -89.1316 17.771967
> -89.0816 17.7742
> -89.0985 17.556067
> -89.12545 17.1805
> -89.1373 16.810567
> -89.15585 16.4474
> -89.19635 16.012267
> -89.19295 15.9628
> -89.1643 15.933567
> -88.9506 15.905167
> -88.9213 15.8822
> -88.88855 15.874167
> -88.8472 15.878767
> -88.81445 15.878767
> -88.774 15.863833
> -88.68785 15.78
> -88.6792 15.754733
> -88.68785 15.7111
> -88.68095 15.700767
> -88.6568 15.691567
> -88.61545 15.690433
> -88.5948 15.698467
> -88.59305 15.7065
> -88.6103 15.724867
> -88.6103 15.738667
> -88.58275 15.771967
> -88.56375 15.783467
> -88.53105 15.783467
> -88.4785 15.771967
> -88.45265 15.7685
> -88.4096 15.7777
> -88.38545 15.778833
> -88.351 15.767367
> -88.31135 15.727167
> -88.23725 15.691567
> -88.3148 15.644467
> -88.51955 15.3572
> -88.64485 15.2584
> -88.88475 15.135133
> -89.0299 15.092333
> -89.18425 15.038367
> -89.2041 15.0231
> -89.21175 14.993533
> -89.198 14.943633
> -89.2576 14.8805
> -89.2698 14.828533
> -89.2652 14.790867
> -89.1781 14.714467
> -89.1506 14.620733
> -89.1598 14.5902
> -89.1934 14.577967
> -89.2759 14.572867
> -89.29275 14.565733
> -89.3019 14.5525
> -89.2933 14.5114
> -89.2863 14.478067
> -89.47335 14.436067
> -89.57965 14.398
> -89.60135 14.369133
> -89.52255 14.3114
> -89.5895 14.245767
> -89.6545 14.231333
> -89.68795 14.201167
> -89.7569 14.048933
> -89.79035 14.016133
> -90.00105 13.976767
> -90.02465 13.962333
> -90.03255 13.934767
> -90.03255 13.901967
> -90.0424 13.887533
> -90.10145 13.891467
> -90.12705 13.878333
> -90.12 13.772533
> -90.11775 13.7392
> -90.1746 13.774267
> -90.4295 13.862867
> -90.63865 13.8992
> -90.9001 13.9166
> -91.3685 13.967433
> -91.49705 13.999367
> -91.59945 14.0647
> -91.6125 14.1068
> -91.6343 14.121333
> -91.64955 14.121333
> -91.667 14.114067
> -91.68875 14.114067
> -91.81295 14.215733
> -91.9524 14.327567
> -92.22255 14.519233
> END # POINTS
> END # FEATURE
> Here is my code:
> Here is my template file:
> http://osgeo-org.1803224.n2.nabble.com/layerObj-queryByPoint-p
roblem-tp7027251p7027251.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
