[mapserver-users] WCS GetCoverage
David Hildebrand
David.Hildebrand at afsc.ca
Thu Nov 24 15:48:42 EST 2011
I am trying to implement a WCS server and am running into difficulty
with GetCoverage and the following request.
REQUEST=GetCoverage&COVERAGE=awifs&CRS=EPSG:4269&BBOX=-116,51,-114,53&RE
SX=100&RESY=100&FORMAT=GTiff&RESPONSE_CRS=EPSG:4269
The following ServiceException is raised.
msImageCreateGD(): Image handling error. Cannot create GD image of size
0x0
I can do a WCS GetCapabilities and DescribeCoverage without error.
Also, when I issue the following WMS request it works fine.
REQUEST=GetMap&LAYERS=awifs&SRS=EPSG:4269&BBOX=-116,51,-114,53&WIDTH=800
&HEIGHT=600&FORMAT=image/png&STYLES=
The GetCoverage and GetMap requests have the same parameters and yet WCS
thinks the image size is 0x0. The MapServer configuration for the layer
file is given below
LAYER
NAME "awifs"
PROCESSING "BANDS=2,1,3"
PROCESSING "SCALE_2=19,159"
PROCESSING "SCALE_1=10,130"
PROCESSING "SCALE_3=9,124"
METADATA
"wcs_label" "awifs"
"wcs_rangeset_name" "RGB"
"wcs_rangeset_label" "rgb"
"wms_title" "awifs"
"wms_opaque" "1"
"ows_resolution" "56 56"
"wms_srs" "EPSG:43001"
END
STATUS off
TYPE raster
DATA "e:/awifs/July.tif"
PROJECTION
"init=epsg:43001"
END
TEMPLATE "empty.html"
DUMP TRUE
END
Thanks for the help.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111124/e9c66060/attachment.html
