[mapserver-users] high memory usage on map draw
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Nov 29 09:49:38 EST 2011
On 11/29/2011 3:20 AM, Daniele Debernardi wrote:
> Hi,
> with mapserver trunk version (but i think with others too) I have to
> generate very big map to be imported in a pdf file.
> I use php mapscript to generate maps with 300 dpi for an A1/A0 pdf page
> or bigger.
> This mean that the map has dimensions like 15000x25000 pxl and when I
> call the MapObj->draw method i get this error:
> PHP Warning: mapObj::draw(): [MapServer Error]: agg2CreateImage():
> mapagg.cpp: 708: Out of memory allocating 1550851152 bytes.
> Map server is configured with the AGG/PNG driver with imagemode RGBA.
> Is it normal that need so much memory to generate the image?
Just for the image buffer you need 15000x25000x4 pixels = 1500,000,000
and AGG might actually allocate a slight larger image buffer so it does
not create edge effects while antialiasing objects close to the edges.
So the above request does not seem unreasonable.
> I already tryied the php ini_set memory_limit but with a limit of 2048M
> i still have some problem with memory.
Try setting the limit a little higher like to 2564-3072M can see if your
memory problems go away. Of course this assumes you have a system with a
lot of memory.
-Steve W
> I checked other possible outputs but generating maps in pdf through
> Cairo driver but doc says that polygons filled with symbols are not
> supported, and for that reason I cant use it.
> SVG output has some limitations too like line drawn without symbols or
> pixmap symbols not supported.
> Is there a better way to generate so big map images and imported in a
> pdf file?
> Hope you guys can help me.
> Daniele
> mapserver-users at lists.osgeo.org
