[mapserver-users] high memory usage on map draw
Daniele Debernardi
daniele at geosar.ch
Tue Nov 29 10:02:53 EST 2011
The solution is not pumping up the memory limit of the server, because
if i get 2 request at the same time
I still have memory problem.
Which is the best way (output format) to generate high resolution map
images with full symbology support?
Il 29.11.2011 15:49, Stephen Woodbridge ha scritto:
> On 11/29/2011 3:20 AM, Daniele Debernardi wrote:
>> Hi,
>> with mapserver trunk version (but i think with others too) I have to
>> generate very big map to be imported in a pdf file.
>> I use php mapscript to generate maps with 300 dpi for an A1/A0 pdf page
>> or bigger.
>> This mean that the map has dimensions like 15000x25000 pxl and when I
>> call the MapObj->draw method i get this error:
>> PHP Warning: mapObj::draw(): [MapServer Error]: agg2CreateImage():
>> mapagg.cpp: 708: Out of memory allocating 1550851152 bytes.
>> Map server is configured with the AGG/PNG driver with imagemode RGBA.
>> Is it normal that need so much memory to generate the image?
> Just for the image buffer you need 15000x25000x4 pixels = 1500,000,000
> and AGG might actually allocate a slight larger image buffer so it
> does not create edge effects while antialiasing objects close to the
> edges. So the above request does not seem unreasonable.
>> I already tryied the php ini_set memory_limit but with a limit of 2048M
>> i still have some problem with memory.
> Try setting the limit a little higher like to 2564-3072M can see if
> your memory problems go away. Of course this assumes you have a system
> with a lot of memory.
> -Steve W
>> I checked other possible outputs but generating maps in pdf through
>> Cairo driver but doc says that polygons filled with symbols are not
>> supported, and for that reason I cant use it.
>> SVG output has some limitations too like line drawn without symbols or
>> pixmap symbols not supported.
>> Is there a better way to generate so big map images and imported in a
>> pdf file?
>> Hope you guys can help me.
>> Daniele
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Cordiali saluti,
Ing. Debernardi Daniele
GEOSAR SA
Via al Ticino 1
CH-6514 Sementina
T: +41 (0)91 840 24 17
F: +41 (0)91 857 67 72
www.geosar.ch
