[mapserver-users] MapCache: Disabling WMS requests for
fully-seeded caches?
thomas bonfort
thomas.bonfort at gmail.com
Tue Nov 29 10:32:42 EST 2011
You can do this by commenting out the <source> block from the tileset
once the wanted tiles have been created. You'll probably also want set
error reporting to return blank images from that stage onwards.
thomas
On Tue, Nov 29, 2011 at 00:09, John Taranu
<jtaranu at firstbasesolutions.com> wrote:
> We have a fully seeded cache that was fully seeded to a polygon outline.
> The intent is to serve the tileset through a variety of services (WMS, TMS)
> using mod-mapcache.
> Tiles that are outside the polygon outline but still within the polygon
> bounding box should be blank tiles. However, a request for one of these
> tiles results in a call to that tileset’s WMS source. This creates
> considerable overhead by starting up MapServer and writing the resulting
> tile to the cache. Is there any way to disable the WMS calls for these
> blank tiles, and instead short-circuit the request to return a blank? That
> is, once a tileset has been fully seeded, is it possible to disable any
> further calls to the WMS, so that requests for tiles that are not in the
> cache return a blank?
> mapserver-users at lists.osgeo.org
