[mapserver-users] MSVCR fault when using OGR and OCI datasources ?
Nicolas BOUTET
nicolas.boutet at geosys.com
Thu Sep 1 05:56:54 EDT 2011
Hello,
Using the 6.0.1 version of MapServer and the 1.8.1 version of GDAL (using
Tamas Szekeres binaries
<http://vbkto.dyndns.org/sdk/PackageInfo.aspx?file=release-1400-x64-gdal-1-8
-1-mapserver-6-0-1.zip> ), I got and error when I try to request a WFS
layer. This layer get data from an Oracle Database using OGR and OCI.
The same layer works well when I use MapServer 5.6 and GDAL 1.7. WMS layers
work well, and WFS GetCapabilities requests are working well also.
Here is the Windows event registered when the GetFeature request is sent :
The Window Event:
Faulting application name: mapserv.exe, version: 0.0.0.0, time stamp:
0x4e208c15
Faulting module name: MSVCR80.dll, version: 8.0.50727.4927, time stamp:
0x4a27427d
Exception code: 0xc0000005
Fault offset: 0x000000000001e272
Faulting process id: 0xabc
Faulting application start time: 0x01cc687fe11d27a6
Faulting application path: D:\wwwRoot\MapServer6\cgi-bin\mapserv.exe
Faulting module path:
C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_n
one_88dce9872fb18caf\MSVCR80.dll
Report Id: 1efbc4e2-d473-11e0-9fc6-005056991513
Here are some part of the MapFile (the definition of the WFS layers is in a
separate file) :
MAP
CONFIG PROJ_LIB
"D:/MapServerProj/nad/"
CONFIG GDAL_DRIVER_PATH
"D:/gdalplugins1.8/"
CONFIG "MS_ERRORFILE"
"D:/MapServerMaps/Errors_MapAgriQuest6.txt"
DEBUG 5
WEB
IMAGEPATH
"D:/wwwroot/MapServer6/temp/"
IMAGEURL "/temp/"
METADATA
"ows_enable_request" "*"
END
END
INCLUDE "MapAgriQuest_Blocks.map"
END # Map
Here is the definition of the layer:
LAYER
NAME "LOCALIZED_BLOCKS"
METADATA
"ows_title"
"LOCALIZED_BLOCKS"
END
VALIDATION
idUser
'^[0-9]{1,6}$' # %idUser% must be numeric and
between 1 and 6 characters
idLanguage
'^[0-9]{1,2}$' # %idLanguage% must be numeric and
between 1 and 2 characters
END
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "OCI:****/****@****"
DATA "SELECT ..
FROM ..
WHERE .."
STATUS ON
END
Best regards
Nicolas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110901/39d7b40f/attachment.html
