[mapserver-users] How does SYMBOLSCALEDENOM work on FONTs?
Jackey Cheung
cheung.jackey at gmail.com
Fri Sep 2 06:11:48 EDT 2011
I've met a problem while playing around with SYMBOLSCALEDENOM. In
attached images, the string on the top without halo is drawn as fixed
size 10px in arial. The lower string was drawn with scaling on in
verdana. However, as you can see, the scaling seems quite awkward. It
doesn't seem to change from 1:10M ~ 1:1M, and suddenly grown to full
size on 500K.
Did I make something wrong?
LAYER
NAME "state"
STATUS default
TYPE polygon
#MINSCALEDENOM 10000
MAXSCALEDENOM 50000000
SYMBOLSCALEDENOM 500000
CONNECTIONTYPE postgis
CONNECTION .......
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "geom FROM view_render_locality USING UNIQUE oid
USING SRID=4326"
LABELITEM "sname"
CLASS
NAME "State/Province"
LABEL
ENCODING "UTF-8"
COLOR 0 0 0
OUTLINECOLOR 255 255 255
TYPE truetype
FONT "verdana"
SIZE 16
POSITION auto
PARTIALS false
MINSIZE 8
MAXSIZE 16
END
END
END
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110902/f49ddb74/1M-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110902/f49ddb74/2M-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110902/f49ddb74/10M-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110902/f49ddb74/500K-0001.png
