[mapserver-users] Crash on Labeling
Stuart.Harlan at modot.mo.gov
Wed Sep 7 16:30:24 EDT 2011
I am labeling roads. I have a class using the TEXT directive like so:
TEXT 'Bus [NAME]'
This is for a business loop and labels in the map correctly with the
highway name in the place of [NAME]. I also have other "Loop"s. I tried
this for the other loops:
TEXT 'Loop [NAME]'
...and I get the following label in the map:
Loop [NAME]
...just like you see it, with brackets and all. Then I did some
experimenting. When I try this in the config file:
TEXT 'q [NAME]'
...the entire process crashes. Yes, that's simply a 'q'. Are there
labeling issues in MapServer 6.0.1? Because, I think I may have found
some. I'm using a custom built binary (MSVC 10) on Windows 7.
Stuart Harlan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110907/40cca6ec/attachment.html
