[mapserver-users] Re: Getting blank tiles in google maps
vaibhavgarg
vaibhavkumargarg at gmail.com
Thu Sep 8 13:47:40 EDT 2011
(retrying message)
Hi all, I am new to MapServer.
I have downloaded and setup MS4W and was able to overlay the example Bath
and other map data on google maps.
I then created my own .map file using QGIS and supplied my data but the
served tiles are completely blank(transparant or white when I select RGB).
My data set is .GML and I also tried converting it to .SHP format. I have
checked that my setup is ok by doing is on two different computers.
When I use shp2img.exe then it renders the layers properly.
c:\> shp2img.exe -m hampshire.map -o hampshire.png -s 2048 2048
I am using this URL scheme:
http://localhost:8088/cgi-bin/mapserv.exe?map=C:/ms4w/apps/gmap/htdocs/hampshire.map&layers=HampshireAreas&mode=tile&tilemode=gmap&tile=[x]+[y]+[z]
I have attached all the relevant files. (2 sets, one is .SHP and the other
is .GML, both cases I get transparent empty tiles)
Can anyone please help me identify the reason why the generated tiles are
transparent and how I can fix it.
(7MB total, 1MB pieces, sorry if this is large, I am new to mailing lists
too, please use 7Z to unzip)
SHP: Hampshire.map Hampshire.7z.001...006
GML: Hampshire-gml.map Hampshire-gml.7z
Download links here: (7z, 7mb total)
http://osgeo-org.1803224.n2.nabble.com/Getting-blank-tiles-in-google-maps-td6746323.html
Alternate download (zip format, 14mb) http://www.megaupload.com/?d=DAD6SR5P
Thanks you very much.
Vaibhav G
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Getting-blank-tiles-in-google-maps-tp6772814p6772946.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
