[mapserver-users] Re: MapScript WMS request
Frank Warmerdam
warmerdam at pobox.com
Thu Sep 8 14:22:04 EDT 2011
Puneet,
I would add that there is a lot of other metadata that you need to set on a
map in order to get WxS services like WMS working. If you haven't done
that either you are going to be frustrated.
I would suggest getting your script working initially with an actual mapfile
and then if you really want to construct the map programmatically use
that as a guide.
Best regards,
On Thu, Sep 8, 2011 at 11:15 AM, Armin Burger <armin.burger at gmx.net> wrote:
> in PHP MapScript should be something like
> $map->setMetaData("ows_enable_request", "*");
> in Python:
> map.setMetaData("ows_enable_request", "*")
> armin
> On 08/09/2011 20:05, Mr. Puneet Kishor wrote:
>> On Sep 8, 2011, at 1:03 PM, thomas bonfort wrote:
>>> it goes in map->web->metadata
>> I guessed as much, but I can't fathom the syntax. The webObj doesn't seem
>> to have any constructor, and I don't see any documentation. Could you please
>> point me to an example?
>>> On Thu, Sep 8, 2011 at 19:48, Mr. Puneet Kishor<punk.kish at gmail.com>
>>> wrote:
>>>> a bit more investigation on producing a WMS response via Perl MapScript
>>>> reveals the following error
>>>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>>>> <!DOCTYPE ServiceExceptionReport SYSTEM
>>>> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
>>>> <ServiceExceptionReport version="1.1.0">
>>>> <ServiceException>
>>>> msWMSDispatch(): WMS server error. WMS request not enabled. Check
>>>> wms/ows_enable_request settings.
>>>> </ServiceException>
>>>> </ServiceExceptionReport>
>>>> So, it seems I have to somehow, somewhere enable 'ows_enable_request'.
>>>> Looking at the documentation, seems like if I had a map file, I could add
>>>> the following line to do so
>>>> ows_enable_request '*'
>>>> However, I am not using a map file at all. Not finding any documentation
>>>> on this setting, I tried the following to no avail
>>>> $map->{ows_enable_request} = '*';
>>>> Suggestions, anyone?
>>>> On Sep 7, 2011, at 10:18 PM, Mr. Puneet Kishor wrote:
>>>>> I would really appreciate insight from someone well-versed in the ins
>>>>> and outs of WMS via MapScript. Looking at the discussion at
>>>>> [http://trac.osgeo.org/mapserver/ticket/670], the `img = wms_map.draw()`
>>>>> step seems to be a crucial part of drawing the image.
>>>>> So, I added `my $img = $map->draw();` to my code below, and indeed, the
>>>>> image was drawn and sent back to the browser.
>>>>> Is this something that should be added to the examples in the
>>>>> documentation? Is this the right way to do things? In any case, I am not
>>>>> write to STDOUT, and sending the buffer directly. Instead, my code is very
>>>>> much like a regular request (and it works) --
>>>>> my $new_extent = $map->{extent};
>>>>> my $req = new mapscript::OWSRequest();
>>>>> $req->setParameter( "SERVICE", "WMS" );
>>>>> $req->setParameter( "VERSION", "1.1.0" );
>>>>> $req->setParameter( "REQUEST", "GetMap" );
>>>>> $req->setParameter( "BBOX", "-180,-90,180,90" );
>>>>> $req->setParameter( "LAYERS", "layer_name");
>>>>> $req->setParameter( "SRS", "-1");
>>>>> $req->setParameter( "WIDTH", "1200");
>>>>> $req->setParameter( "HEIGHT", "600");
>>>>> my $dispatch_out = $map->OWSDispatch( $req );
>>>>> my $map_img = 'test_' . sprintf("%0.10d", rand(1000000000)) .
>>>>> '.png';
>>>>> $img->save("/path/to/$map_img");
>>>>> return send_file("/path/to/$map_img");
>>>>> Comments? Corrections?
>>>>> On Sep 7, 2011, at 6:12 PM, Mr. Puneet Kishor wrote:
>>>>>> On Sep 7, 2011, at 5:49 PM, Mr. Puneet Kishor wrote:
>>>>>>> I am trying to convert my MapScript program to a WMS responder. I
>>>>>>> create my $map where I set all the layers and classes and colors, etc, just
>>>>>>> like for a normal, non-WMS request that works perfectly correctly.
>>>>>>> my $map = undef;
>>>>>>> $map = mapObj(name => 'mymap') unless defined $map;
>>>>>>> $req->setParameter( "REQUEST", "GetCapabilities" );
>>>>>> I changed the above line to
>>>>>> $req->setParameter( "REQUEST", "GetMap");
>>>>>> but, still no improvement.
>>>>>>> mapscript::msIO_installStdoutToBuffer();
>>>>>>> printf "%s\n", mapscript::msIO_getStdoutBufferString();
>>>>>>> Except, the above doesn't really do anything for me. I get nothing in
>>>>>>> my browser. Suggestions?
>>>>>>> Puneet Kishor
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
and watch the world go round - Rush | Geospatial Software Developer
