[mapserver-users] how to specify the location of projection
library, how to do it not in map file?
JK Chen
jk.chen at sdl.usu.edu
Thu Sep 8 17:40:47 EDT 2011
Hi Steve,
How to do it via Apache configuration? What is the syntax? Is it like this:
"PROJ_LIB" "./cgi-bin/"
Nope, we can't over-write the path names.
Thanks for your helps.
JK
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Thursday, September 08, 2011 3:06 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] how to specify the location of projection library, how to do it not in map file?
On 9/8/2011 5:02 PM, Stephen Woodbridge wrote:
> On 9/8/2011 5:05 PM, JK Chen wrote:
>> Hi,
>> I specify the location proj library in the map file, which points to
>> apache cgin-bin dirs.. Because we have 32 bit and 64 bit machines,
>> and the paths of the apache software on those two types machines are
>> not the same, I end up having two map files.
>> That creates installation problems for us. I'm wondering if there is
>> more elegant way to specify the path to proj library?
>> In basegn.x32.map
>> CONFIG "PROJ_LIB" "C:/Program Files/Apache Software
>> Foundation/Apache2.2/cgi-bin/"
>> In basegn.x64.map
>> CONFIG "PROJ_LIB" "C:/Program Files (x86)/Apache Software
> I believe you can set this up as an environment variable in each
> apache instance so so it points to the correct file. You would have to
> do this in the apache config file(s).
See:
http://trac.osgeo.org/mapserver/wiki/EnvironmentVariables
If you can do it in the apache config because you do not have access to it, you could write a simple wrapper script the exports the enviroment variable and then executes mapserver.
-Steve W
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
