[mapserver-users] Re character encoding
Chris Jackson
webturtles at gmail.com
Wed Sep 7 14:40:45 EDT 2011
Hi Jeff
I may well try that! The trouble is I have a stack of attributes in a
Access db which I was joining onto the KML data. I need the complete
dataset for an ArcGIS Server data service anyway so a shapefile seemed to be
a good way to join it all and assist with that (will end up in SDE) and my
mapfile dataset too. I had already read the page you mentioned and all is
in place (I am using the MS4W PHP/mapscript set-up on IIS) and my original
ISO flavoured version labels up nicely - it just breaks some of the query
functionality (though it shouldn't - which is why I wonder if some of the
characters are badly formed)!
Thanks for the advice
Chris
Hi Chris,
> My quick thoughts are:
> - use ogr2ogr (the GDAL/OGR library) to do your conversion from KML to
> shp (if you are on Windows, the MS4W product can help you with that
> http://www.maptools.org/ms4w/index.phtml?page=downloads.html)
> - another option is to use the KML in its native format with MapServer
> (http://www.mapserver.org/input/vector/kml.html), which is also possible
> with MS4W
> - if by "application" problems you mean map label problems with encoded
> characters, this howto should help you:
> http://www.mapserver.org/mapfile/labelencoding.html
> Hope that helps.
> -jeff
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110907/e35d04cc/attachment.html
