[mapserver-users] Use EXTENT to crop an image within a map file
Enzmann, Alexander R.
xander at mitre.org
Fri Sep 9 10:28:38 EDT 2011
Is it possible to only use a subset of an image that is referenced in a mapfile? In the mapfile below there are two FAA sectional charts. There are borders on the charts that I don't want on the final composite image.
If the "EXTENT" actually clipped the image before rendering, I could get what I'm looking for, but it only seems to be used to determine overlap with the bounds of the output image (and not always then).
I'm sure I could use something like gdal_translate to preprocess all of the charts, but that a really tedious sort of task and results in extra images lying around. Would prefer to use source images and have the mapfile pull the correct bits out of them.
The charts are available at: http://aeronav.faa.gov/index.asp?xml=aeronav/applications/VFR/chartlist_sect
Xander
# MapServer map file for FAA Sectional Raster charts (test case w/ only two charts)
MAP
NAME "FAA Sectional Raster"
IMAGETYPE PNG
SIZE 256 256
DEBUG OFF
UNITS DD
SHAPEPATH "/MapData/FAA/SectionalRaster"
PROJECTION "init=epsg:4269" END
WEB
METADATA
"wms_srs" "EPSG:900913 EPSG:4326"
"ows_enable_request" "*"
END
END
LAYER
NAME "LA North" DATA "Los Angeles 89 North.tif"
STATUS ON TYPE RASTER DUMP TRUE PROJECTION "auto" END
END
LAYER
NAME "LA South" DATA "Los Angeles 89 South.tif"
PROJECTION "+proj=lcc +lat_1=38.66667 +lat_2=33.33333 +lat_0=34.16667 +lon_0=-118.5" END
EXTENT -122 32 -119 34 END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110909/8fa912e3/attachment.html
