[mapserver-users] JSON template fail
Mr. Puneet Kishor
punk.kish at gmail.com
Sun Sep 11 00:09:37 EDT 2011
I was unable to achieve success with the suggestion for template at [http://mapserver.org/output/template_output.html]. So, I simplified my template like so --
// mapserver template
"gid": "[gid]",
"attrib1": "[attrib1]",
"attrib2": "[attrib2]",
"attrib3": "[attrib3]"
In my map file I have an output format declared like so
OUTPUTFORMAT
NAME "json"
DRIVER "TEMPLATE"
MIMETYPE "application/json"
FORMATOPTION "FILE=/Users/punkish/Documents/www/gmap/lib/template.html"
END
Note: MapServer croaks if I name the template "template.json"
The output from MapServer is
1: {
2: "gid": "2676",
3: "attrib1": "foo",
4: "attrib2": "bar",
5: "attrib3": "baz"
6: }
gmap:-1 Resource interpreted as Script but transferred with MIME type text/html.
gmap:2 SyntaxError: Parse error
So, in spite of declaring the MIMETYPE as "application/json", the result is sent back with a "text/html" mime type (could that be because the template ends in .html?). And, what on earth is the "SyntaxError"? I don't see any. Does anyone?
