[mapserver-users] mapserver scalebar
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Sep 16 07:05:47 EDT 2011
A meter based scalebar cannot work very well with epsg:4326 because the more north you go the narrower is the 1 degree slice in east-west direction. Therefore you will have a different scale in the top of the map and in the bottom. Some estimate could be done according to the latitude in the middle of the image, in your case ~120 m. However, the scale is also different in the east-west and south-north directions.
Use a coordinate system like UTM and the scalebar will be right. EPSG:3857 has the same trouble with scale changing according to latitude, though in a bit different way. Lappland is not as wide as in this map, not to mention the gigantic Svalbard http://osm.org/go/1mH7
-Jukka Rahkonen-
Lars Lingner wrote:
> Hello,
> I have an issue with the mapserver scalebar. Hopefully it is just my
> understanding thats wrong.
> My data is epsg:4326 which is also used for displaying the
> map requested
> via wms.
> When I embed a scalebar, the length of it isn't correct. It show an
> value about as twice (200+ meter) the right value (~120 m).
> The region I'm displaying is in northern europe about 55.8 latitude.
> My mapfile looks like this:
> MAP
> UNITS METERS
> EXTENT ....
> PROJECTION
> "init=epsg:4326"
> END
> SCALEBAR
> IMAGECOLOR 255 255 255
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> STYLE 1
> SIZE 100 3
> COLOR 0 0 0
> UNITS METERS
> INTERVALS 2
> POSITION lc
> TRANSPARENT TRUE
> STATUS EMBED
> END
> WEB
> METADATA
> "wms_title" "WMS"
> "wms_srs" "epsg:4326"
> "wms_extent" ...
> "wms_onlineresource" "http://example.com/cgi-bin/mapservice"
> END
> END
> [LAYERCONFIGURATION]
> END
> I'm using MapServer 5.6, data comes from shapefiles and Postgis-DB.
> It is quite important to have an scalebar rendered in the image so the
> user can estimate the objects length.
> I also tested the scalebar from OpenLayers and for epsg:4326 its also
> wrong. When I use epsg:3857 with the geodesic=true option the scalebar
> in OpenLayers looks correct. Whereas MapServer is still wrong.
> Is MapServer able to calculate an correct scalebar for 4326?
> Should I use an other projection?
> In which cases does MapServer create a reliable scalebar?
> Thank you in advance for any hints.
> Lars
> mapserver-users at lists.osgeo.org
