[mapserver-users] problem with mercator projection
fred p
mapoubelle22 at gmail.com
Wed Sep 21 04:31:18 EDT 2011
Hello !
I am trying to serve an image in Mercator projection (EPSG:3395) with an
extent larger than "360° in longitude" but I get a truncated and reversed in
longitude image.
Do I make a mistake somewhere?
Thanks for your help
The mapfile content and the gdalinfo output on the original image are given
below.
Mapserver version: 6.0.1
Call to mapserver:
/path/to/mapserv -nh "QUERY_STRING=map=/tmp/world.
map&service=wms&LAYERS=countries&FORMAT=image/png&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=epsg:3395&BBOX=-26080550.098232,-15000000,26080550.098232,15000000&WIDTH=885&HEIGHT=509"
Content of the mapfile:
MAP
EXTENT -180 -90 180 90
IMAGECOLOR 255 255 255
IMAGETYPE agg
STATUS ON
OUTPUTFORMAT
NAME "agg"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE "RGBA"
TRANSPARENT TRUE
FORMATOPTION "INTERLACE=false"
END
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_srs" "epsg:4326 epsg:3395 epsg:900913 epsg:3995"
"OWS_ENABLE_REQUEST" "*"
END
END
LAYER
DATA "/tmp/world.tif"
NAME "countries"
PROJECTION
"init=epsg:4326"
END
STATUS ON
TYPE RASTER
END
END
Output of gdalinfo command:
$ gdalinfo /tmp/world.tif
Driver: GTiff/GeoTIFF
Files: /tmp/world.tif
Size is 1000, 500
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.360000000000000,-0.360000000000000)
Metadata:
TIFFTAG_DOCUMENTNAME=/tmp/world.tif
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0'0.01"E, 0d 0'0.01"N)
Band 1 Block=1000x8 Type=Byte, ColorInterp=Gray
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110921/fa0fccde/attachment-0001.html
