[mapserver-users] WMS layers get canceled
Puneet Kishor
punk.kish at gmail.com
Thu Sep 22 22:17:11 EDT 2011
I am unable to figure this out --
My app front is Google Maps API v3 with MapServer 6.0.1
$./mapserv -v
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
The app fires WMS requests that look like so in Firebug and Safari Web Inspector (one per tile)
http://path/to/server/cgi-bin/app?version=1.1.1&request=GetMap&format=image/png&TRANSPARENT=TRUE&Styles=&SRS=EPSG:4326&Layers=lyr&width=256&height=256&BBOX=-135,40.97989806962013,-90,66.51326044311185
The status code in Firebug is "Aborted" ("Canceled" in Safari Web Inspector). The ms_error file kicks in the following messages --
[Thu Sep 22 21:00:55 2011].347078 msWMSLoadGetMapParams(): enabling non-square pixels.
[Thu Sep 22 21:00:55 2011].347608 msDrawMap(): kicking into non-square pixel preserving mode.
[Thu Sep 22 21:00:55 2011].347615 msDrawMap(): rendering using outputformat named png24 (AGG/PNG).
My .map file has the following incantation --
#### in the MAP section #####
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
ows_enable_request "*"
wms_abstract "blah blah"
wms_accessconstraints "none"
wms_title "gpsvecs"
wms_onlineresource "http://path/to/server/cgi-bin/gpsvecs?"
wms_srs "EPSG:4326"
wms_keywordlist "foo,bar"
wms_enable_request "*"
END
END
#### in the LAYER section ####
LAYER
NAME "lyr"
CONNECTION "host=localhost port=5432 dbname=db user=user password=passwd"
CONNECTIONTYPE POSTGIS
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "the_geom FROM (SELECT gid, a, b, the_geom FROM table) foo USING UNIQUE gid USING srid=4326"
PROJECTION
"init=epsg:4326"
END
METADATA
wms_srs "EPSG:4326"
wms_title "lyr"
wms_extent "-180 -90 180 90"
END
Suggestions?
