[mapserver-users] PHP Mapscript - debugging help
Carlos Ruiz
boolean10001 at yahoo.com
Tue Sep 27 10:31:29 EDT 2011
Ian,
>We have moved from 5.x to 6.x are chasing an issue causing a segmentation
fault which appears to be related to the way we are
> defining the
symbols.
Are you talking about the SYMBOLSET file definition ? The segmentation fault throws when you invoke map->draw() ?
> We used to print_r the map object and then compare the one created from
the map file and the one we had created programmatically,
> however with
mapserver 6.x the print_r on the map object is empty.
If you can have both map objects (the one loaded and the other one created) I suggest you to use the map->save(file name) method to see the differences between them.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Monday, September 26, 2011 12:54 PM
Subject: [mapserver-users] PHP Mapscript - debugging help
Hello,
We have moved from 5.x to 6.x are chasing an issue causing a segmentation fault which appears to be related to the way we are defining the symbols.
If we create the map object from an empty map file (with just MAP and END in it) then we do not get a segmentation fault, sounds like something not initialized I know…
Any ideas on this appreciated but here is the real question (and it may really be a php question) :-
We used to print_r the map object and then compare the one created from the map file and the one we had created programmatically, however with mapserver 6.x the print_r on the map object is empty.
I am sure this is basic PHP but any help would be appreciated.
Thanks
Ian
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110927/6089c0d1/attachment.html
