[mapserver-users] Rendering weather data
Brent Fraser
bfraser at geoanalytic.com
Tue Sep 27 15:11:34 EDT 2011
Bob,
Maybe. I had considered some kind of programmed CGI-based URL
function to create the wind barb (hence the interest in UCAR's NCL), but
I don't think mapserver has the capability to use a URL as a symbol
reference (would be a nice enhancement).
I don't know how to procedurally add components within a map file
using CLASS, STYLE, and SYMBOL. Could be done with MapScript I suppose....
Best Regards,
Brent Fraser
On 9/27/2011 11:54 AM, Bob Basques wrote:
> Could the barb class be built up from primitives, stem anddifferent
> flags on the tail, based on the numbers passed in. Basically you
> would be writing the barb symbol out for each label location needed,
> instead of sampling from a list of many? Just use a max/min
> thresholding to decide when the symbol has something added to it or
> not. Still a bit laborious to setup, but I think it gets you there.
> bobb
> >>> Brent Fraser <bfraser at geoanalytic.com> wrote:
> At FOSS4G I was struck by the number of presentations involving
> weather data and time series display. Maybe I noticed because I have a
> need to render wind velocity in KML, and while I haven't settled on
> mapserver to do the rendering I've been wondering how to render wind
> barb symbols (see attached graphics) efficiently.
> One problem is the source data: the magnitude is in one raster file
> (GRIB format, float64) and the direction in another. GDAL's OGR
> library will read the GRIB files, but I don't know of any way to use two
> rasters to define a vector layer. I think there is some work going on
> with respect to displaying vector field data in mapserver, so maybe this
> will be solved by that work. Otherwise pre-processing the two rasters
> into a point datasource containing lon,lat,speed,direction attributes
> may be the way to go.
> The other issue of wind barb symbol rendering may have to be solved
> by hand constructing a barb for 0 knots, 5 knots, etc (50-ish symbols?)
> , and having 50-ish corresponding classes (this could be a performance
> problem for mapserver). But I'm open to better ideas... SLD? HTTP/CGI
> request?, something like one class of:
> CLASS
> STYLE
> GEOMTRANSFORM "start"
> COLOR 0 255 0
> SIZE 15.0
> SYMBOL "http://localhost/symbolgen?[speed]"
> ANGLE [direction]
> END
> END
> but likely the cost of getting the symbol would be greater that
> creating 50 separate class objects.
> And for those interested in mapping and graphing weather data, have a
> look at http://www.ncl.ucar.edu/Applications/
> especially http://www.ncl.ucar.edu/Applications/barb.shtml
> Best Regards,
> Brent Fraser
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110927/b0f132f7/attachment.html
