[mapserver-users] minscaledenom puzzle, Mapserver 6.0.1
Peter N. Schweitzer
pschweitzer at usgs.gov
Tue Sep 27 16:55:39 EDT 2011
Surely I have misunderstood minscaledenom or otherwise have misused it.
I just switched over to Mapserver 6.0.1 (Linux, CentOS, data in
PostgreSQL+PostGIS)
The web page is http://mrdata.usgs.gov/mineral-resources/mrds-us.html
Feature type is point. The classes from the map file are these:
labelitem "site_name"
labelmaxscaledenom 250000
classitem "dev_stat"
class
maxscaledenom 7000000
expression ('[dev_stat]' == 'Producer' or '[dev_stat]' == 'Past Producer')
name "Mine, past or present producer"
color 160 0 0
symbol "mine"
size 5
label
color 0 0 0
size 10
type truetype
font arial
position cr
offset 4 4
end
end
class
expression ('[dev_stat]' == 'Prospect' or '[dev_stat]' == 'Occurrence')
name "Prospect or occurrence"
color 0 160 0
symbol "opensquare"
size 5
end
class
expression ('[dev_stat]' == 'Plant')
name "Processing plant"
color 0 0 160
symbol "mine"
size 6
label
color 0 0 0
size 10
type truetype
font arial
position cr
offset 4 4
end
end
class
expression ('[dev_stat]' == 'Unknown')
name "Unknown"
color 0 0 0
symbol "occurrence"
size 6
end
class
minscaledenom 7000000
color 160 0 0
symbol 0
end
Under mapserver 5.6.7, this generated red pixels for every point when
the map is zoomed out; those are replaced by the square symbols when
the map is zoomed in.
But under 6.0.1, I am not getting the 1-pixel symbols when zoomed out.
I assumed that the last class defined above would apply when the scale
is coarser than 1:7M.
Here is the OpenLayers command that loads this layer:
var wms = new OpenLayers.Layer.WMS(
"Mineral Resources",
"http://mrdata.usgs.gov/cgi-bin/mapserv?",
map: 'mrds.map',
transparent: 'true',
layers: 'mrds'
singleTile: 'true',
ratio: 1
Would some modification of my map file or my OpenLayers javascript
bring back my little red pixels?
Thanks for any help you might offer.
Peter
Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
(703) 648-6533 FAX: (703) 648-6252 email: pschweitzer at usgs.gov
<http://geology.usgs.gov/peter/>
