[mapserver-users] TILEINDEX layer problem mapserver 6.0.1
Simon Mercier
mercier.simon at gmail.com
Fri Sep 30 11:57:10 PDT 2011
Hi Jukka,
Daniel find it :-) This was a problem with the spatial reference file of ECW
format. This problem was already identified and well fixed in GDAL 1.8.1.
http://trac.osgeo.org/gdal/ticket/4131
thank's a lot
simon mercier
2011/9/29 Daniel Morissette <dmorissette at mapgears.com>
> On 11-09-28 02:57 PM, Rahkonen Jukka wrote:
>> So gdalinfo with Upper Left ( 0.0, 0.0) etc. means that gdal cannot
>> get the correct georeferencing for your images. They are placed at
>> coordinates (0,0) instead and then the WMS BBOX does not intersect the image
>> area and server is sending a white map for you.
> Your analysis is correct, the invalid extents returned by GDAL are likely
> the source of the problem for MapServer. I am checking with Simon off-list
> to try to understand why this is happening.
> And "ERROR 1: Maximum number of characters allowed reached." suggests that
>> for some part of the system the file path is too long. I have never seen
>> such an error but I would still take it seriously and have a try placing the
>> images into a a place like /mnt/pathtest/image_01.ecw
> I did a quick grep on the GDAL source, and it seems that this error message
> would be returned by the CPLReadLine2L() function, so I'd think it is
> unlikely to be related to the length of the file path.
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> ______________________________**_________________
> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110930/03382d65/attachment.htm>
More information about the MapServer-users
