[mapserver-users] MapServer CGI 5.6.6 and MapServer CGI 6.0.2
image quality varies.
Chandrakant Dinni
chandrakant.dinni at edurite.com
Mon Apr 2 02:10:51 EDT 2012
Thanks that resolved the issue.
I was requesting the image as png, so added below lines to map file
with jpeg substituted for png.
Thank you for the quick reply :)
Regards,
Dinni
On Mon, Apr 2, 2012 at 11:11 AM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> how are you requesting the image ?
> you can add this to your mapfile:
> outputformat
> name "aggjpeg"
> driver "AGG/JPEG"
> mimetype "image/jpeg"
> imagemode rgb
> end
> On Mon, Apr 2, 2012 at 06:47, Chandrakant Dinni
> <chandrakant.dinni at edurite.com> wrote:
>> Hi,
>> The attached images are from same map files (bluemarble imagery from
>> http://visibleearth.nasa.gov/view.php?id=57752) .
>> 1)Improper_Mapserver5.6.6.JPG the colours are not smooth,the picture
>> is pixellated in Mapserver 5.6.6
>> 2) Proper_Mapserver6.0.2.JPG the colours are smooth in Mapserver 6.0.2.
>> How can I make the image show properly in 5.6.6, what makes the difference ?
>> Tried using untiled images but the result is the same in 5.6.6.There
>> could me some mapserver setting or preprocessing to be done on image
>> files.
>> Right now I am doing only this to get the final images.
>> gdal_translate -co TILED=YES land_shallow_topo_8192.tif
>> land_shallow_topo_8192_TILED.tif
>> gdaladdo --config GDAL_CACHEMAX 1500 -r average
>> land_shallow_topo_8192_TILED.tif 4 8 16 32 64 128 256
>> Also any know any better\more detailed sources for public domain atlas
>> images,I am also using http://www.naturalearthdata.com/ as a source of
>> data.
>> Thanks in advance....I am planning to use Mapserver 5.6.6 because the
>> Fusion JavaScript Client is compatible with 5.6.6.
> don't know the specifics of fusion, but if it's javascript only I
> don't think it wouldn't work with 6.0.
> regards,
> thomas
>> I am using ms4w for testing ,though final server will be on linux.
>> Below is the map file.
>> MAP
>> NAME "BlueMarble"
>> PROJECTION
>> # "init=EPSG:4326"
>> "proj=latlong"
>> END
>> STATUS ON
>> SIZE 10800 5400
>> EXTENT -180 -90 180 90
>> UNITS DD
>> SHAPEPATH "../NaturalEarth"
>> # don't need background colour
>> # IMAGECOLOR 128 128 255
>> # Start of web interface definition
>> WEB
>> IMAGEPATH "/ms4w/tmp/ms_tmp/"
>> IMAGEURL "/ms_tmp/"
>> METADATA
>> "wms_title" "WMS Server"
>> "wms_onlineresource"
>> "http://172.16.1.126/cgi-bin/mapserv.exe?map=/ms4w/data/mapfiles/bluemarble.map&"
>> "wms_extent" "-180 -90 180 90"
>> "wms_enable_request" "*"
>> END
>> END # WEB
>> LAYER
>> NAME "NasaBlueMarbleOffline"
>> DATA "./bluemarble/land_shallow_topo_8192_TILED.tif"
>> STATUS ON
>> TYPE RASTER
>> PROJECTION
>> "proj=latlong"
>> END
>> METADATA
>> "wms_srs" "EPSG:4269 EPSG:4326"
>> "wms_title" "Nasa Blue Marble Offline"
>> END
>> END
>> LAYER
>> NAME "world_land"
>> DATA "./50m_physical/50m_land.shp"
>> STATUS OFF
>> TYPE POLYGON
>> OPACITY 100
>> CLASS
>> NAME 'Land Outline'
>> STYLE
>> OUTLINECOLOR 184 138 0
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "Land Outline"
>> END
>> END # LAYER
>> LAYER
>> NAME "world_freshwater_bodies"
>> DATA "./50m_physical/50m_rivers_lake_centerlines.shp"
>> STATUS OFF
>> TYPE LINE
>> OPACITY 100
>> CLASS
>> NAME 'Fresh Water Bodies'
>> STYLE
>> OUTLINECOLOR 51 102 255
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "Freshwater Bodies Of The World"
>> END
>> END # LAYER
>> LAYER
>> NAME "world_lakes"
>> DATA "./50m_physical/50m_lakes.shp"
>> STATUS OFF
>> TYPE POLYGON
>> OPACITY 100
>> CLASS
>> NAME 'Lakes'
>> STYLE
>> COLOR 0 61 245
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "Lakes Of The World"
>> END
>> END # LAYER
>> LAYER
>> NAME "geographic_points"
>> DATA "./50m_physical/50m_geography_regions_points.shp"
>> STATUS OFF
>> TYPE POINT
>> OPACITY 50
>> CLASS
>> LABEL
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> FONT "sans"
>> TYPE truetype
>> SIZE 6
>> POSITION AUTO
>> PARTIALS FALSE
>> END
>> END # CLASS
>> METADATA
>> "wms_title" "Major Geographic Points"
>> END
>> END # LAYER
>> LAYER
>> NAME "countries"
>> DATA "./country2007/cntry07_econ.shp"
>> STATUS OFF
>> TYPE POLYGON
>> CLASS
>> NAME 'The Countries Of The World'
>> STYLE
>> OUTLINECOLOR 0 0 0
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "The Countries Of The World"
>> END
>> END # LAYER
>> LAYER
>> NAME "state_lines_usa"
>> DATA "./50m_cultural/ne_50m_admin_1_states_provinces_shp.shp"
>> STATUS OFF
>> TYPE POLYGON
>> CLASS
>> NAME 'States Lines USA'
>> STYLE
>> OUTLINECOLOR 0 0 0
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "States Lines USA"
>> END
>> END # LAYER
>> LAYER
>> NAME "urban_areas"
>> DATA "./50m_cultural/ne_50m_urban_areas.shp"
>> STATUS OFF
>> TYPE POLYGON
>> CLASS
>> NAME 'Urban Areas'
>> STYLE
>> OUTLINECOLOR 0 0 0
>> END # STYLE
>> END # CLASS
>> METADATA
>> "wms_title" "Urban Areas"
>> END
>> END # LAYER
>> #LAYER
>> # NAME "populated_places"
>> # DATA "./50m_cultural/ne_50m_populated_places.shp"
>> # STATUS OFF
>> # TYPE POINT
>> # METADATA
>> # "wms_title" "Populated Places"
>> # END
>> #END # LAYER
>> END # MAP
>> Regards,
>> Dinni.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
