[mapserver-users] GetFeatureInfo results: Search returned no
results
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Apr 10 02:59:23 EDT 2012
Perhaps you do not hit the points? See tolerance and toleranceunits in http://mapserver.org/mapfile/layer.html and set tolerance to quite many pixels for eliminating the possibility that your click just does not hit the target.
If that does not help I would have another try by copying the data from PostGIS ínto shapefile and dublicating the layer. If GetFeatureInfo works with shapefile then the trouble must have something to do with communication with PostGIS.
I wonder why do you have layer status=OFF instead of ON.
-Jukka Rahkonen-
Neelima Emmani wrote:
Hi All,
I am having a problem in retrieving getfeatureinfo. Result in the browser is
GetFeatureInfo results: Search returned no results.
* Below is the url, i am accessing to get feature info -
http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&Layers=maps&SRS=EPSG:4326&BBOX=-83.61145,24.726875,-78.118286,27.196014&X=529&Y=228&WIDTH=1000&HEIGHT=500&QUERY_LAYERS=maps
* Map file -
MAP
NAME "MH"
# Map image size
SIZE 600 600
UNITS meters
EXTENT -86.731680 24.422064 -76.149835 30.424575
FONTSET './etc/fonts.txt'
SYMBOLSET './etc/symbols.txt'
CONFIG "PROJ_LIB" "C:/ms4w/httpd.d/proj/nad/"
PROJECTION
'proj=longlat'
'ellps=WGS84'
'towgs84=0,0,0,0,0,0,0'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE agg
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/ms4w/tmp/ms_tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/ms_tmp/'
# WMS server settings
METADATA
'ows_title' 'MH'
'ows_onlineresource' 'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&'
'ows_srs' 'EPSG:4326 EPSG:900913'
'ows_enable_request' 'GetMap GetFeature GetFeatureInfo *' ##necessary
"wms_feature_info_mime_type" "text/html"
"wms_getfeatureinfo"
"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&"
"wms_featureinfoformat" "text/html"
"wfs_abstract" "This text describes my WFS service."
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'template.html'
END
LAYER
NAME 'maps'
TYPE POINT
DUMP true
HEADER 'header.html'
FOOTER 'footer.html'
CONNECTIONTYPE postgis
CONNECTION "dbname='postgis' host=localhost port=5432 user='postgres' password='xxxxxx' sslmode=disable"
DATA 'the_geom FROM "maps" USING UNIQUE id USING srid=4326'
FILTER ( geometrytype("the_geom") IN ('POINT','MULTIPOINT') )
METADATA
'ows_title' 'maps'
'wfs_typename' 'maps'
'wfs_version' '1.0.0'
'wfs_connectiontimeout' '60'
'wfs_maxfeatures' '150'
'wfs_filter' 'GET'
'wms_include_items' 'all'
'wfs_featureid' 'the_geom'
'gml_include_items' 'all'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'no_defs'
END
CLASS
NAME 'maps'
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 170 211 227
END
END
END
END
Template.html --
<!-- MapServer Template -->
<tr><td>[lrn]</td><td>[NAME]</td><td>[LAT]</td><td>[LON]</td><td>[ELEVATION]</td><td>[QUADNAME]</td></tr>
header.html--
<font size+1><b>Layer: airports</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr bgcolor=#CCCCCC><td bgcolor=#ffffff> </td><th>name</th><th>latitude</th><th>longitude</th><th>address</th><th>description</th></tr>
footer.html --
</table><p>
If any finds any fault with my code or anything that should be added to get feature info then please let me know.
Awaiting reply.
With Regards,
Neelima Emmani
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/e0f66753/attachment.html
