[mapserver-users] labels problem
Karina Guardado
kguardado at gmail.com
Tue Apr 10 10:10:36 EDT 2012
Hi Fernando,
Thank you very much for your reply , you know I found the problem and it
was the .ttf file so I download another arial.ttf for example and then it
worked fine.
I have another question, is it possible that Mapserver have something like
the Map tips of Arcgis? or is it related with other software like
Openlayers for example?
best regards,
karina
On Tue, Apr 10, 2012 at 6:11 AM, Fernando Norte
<fernando at globalgeo.com.br>wrote:
> Hi Karina,
> I need more information about your mapfile and font file to help you, try
> to paste the code here or use http://pastebin.com/.
> Try check if had any error in the mapfile, you can view this error just
> showing the map with mode=map or declare a error log file in the mapfile
> with: CONFIG "MS_ERRORFILE" "/path/to/file.log"
> Maybe you not specify the FONT, or another error in mapfile.
> Att,
> 2012/4/10 Karina Guardado <kguardado at gmail.com>
>> Hi,
>> I'm having problems with labels on my mapfile, when I use the
>> parameter TYPE TRUETYPE then I can't see the map but when I erase this
>> line I can see the map but never see the labels. I have checked the
>> path to the fonset file and it is ok, also I have verified the .ttf
>> file corresponding to the font exist. Any idea about this problem, I'm
>> using mapserver 5.6.5
>> regards
>> Karina Guardado
>> El Salvador
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/c9b07fed/attachment.html
