[mapserver-users] Turn off anti-alias Mapserver 6.0
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 12 03:59:18 EDT 2012
On Thu, Apr 12, 2012 at 06:20, Thomas Joseph <Thomas.Joseph at awtwater.com> wrote:
> We have recently upgraded from Mapserver 5.7 to 6.0 and although the AGG
> anti-alias lines look great the output image size has increased
> significantly from the previous rendering without anti-alias. I was just
> wondering if there is a way to turn off the anti-alias for polyline
> rendering in Mapserver 6.0. From the documentation it appeared that the
> previous GD driver did not include anti-alias by default. We have
> attempted to switch the outputformat from the new default AGG to the
> previous GD driver using the outputformat directive in the map file as shown
> below. This changed the image size slightly suggesting that mapserver was
> using a different driver to render, however the lines were still rendered
> with anti-alias on and the image was still relatively large compared to
> previous mapserver verison.
> OUTPUTFORMAT
> NAME "GDpng"
> DRIVER GD/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGB
GD only supports PC256. If you set imagemode to RGB as here, mapserver
will switch back to AGG.
thomas
> EXTENSION "png"
> END
> Previously in Mapserver 5.7 we did not specify an outputformat we simply
> used IMAGETYPE PNG24 and the output was generated without anti-alias. Any
> suggestions would be greatly appreciated. If you need additional
> information let me know.
> tom
> ________________________________
> THIS EMAIL IS CONFIDENTIAL. Its use or disclosure by any person other than
> the addressee is unauthorised. Anyone other than the intended recipient
> must not rely on the content of this email or any attachment to it. The
> sender cannot guarantee that this email or any attachment to it is free of
> computer viruses or other conditions which may damage or interfere with
> other computer systems.
> mapserver-users at lists.osgeo.org
