[mapserver-users] Passing a mapfile via CGI
Brent Fraser
bfraser at geoanalytic.com
Mon Apr 16 12:41:21 EDT 2012
Bob,
What kinds of things are you trying to do with layers? Are the
layers vectors? Maybe there's a different way...
I'm in the midst of an implementation where the vectors are held in
PostGIS in three tables (point, line and polygon) and joined to a
"feature definition" table (to supply rendering values). I use one map
file with three layers (point, line, polygon) and pass a FILTER
variable to get my different layers which are then rendered.
Here's a snippet from the polygon layer:
CLASS
STYLE # Polygon Fill
SYMBOL [polyfill_symbol]
COLOR [polyfill_fillcolor]
ANGLE [polyfill_angle]
SIZE [polyfill_hatchgap] # e.g Hatching gap
WIDTH 1 # [polyfill_hatchthick] # Hatching
line thickness (column binding doesn't seem to work)
# OPACITY 50 # [attribute] # warning: there is no
OPACITY for LABEL so don't bother.
END
STYLE # Polygon Outline
SYMBOL [geom_symbol]
OUTLINECOLOR [geom_outcolor]
SIZE [geom_width] # for "simple" (?) symbols
WIDTH [geom_width] # for complex symbols
END # Style
TEXT ([gid])
LABEL
TYPE TRUETYPE
FONT [label_font]
ANTIALIAS TRUE
COLOR [label_fillcolor]
OUTLINECOLOR [label_outcolor]
BUFFER 1
POSITION cc # [ul|uc|ur|cl|cc|cr|ll|lc|lr|auto]
PARTIALS TRUE
SIZE [label_height]
END # LABEL
END # class
While this method is suitable for rendering, it will be a problem if you
want store variables for use in an identify operation (or maybe not; I
wonder if a template name can be bound to a database column...)
Best Regards,
Brent Fraser
On 4/16/2012 10:22 AM, Bob Basques wrote:
> All,
> Did anything ever develop from this idea? I need to generate a
> variable length list of layers pro grammatically.
> I'm not finding anything from a quick search of things related to
> passing a MAPFILE via the CGI call. I want to be able to generate a
> MAPFILE, or chunks of it, on the fly. A possible solution (maybe
> scary security wise) would be to use a param like "INCLUDE_<someID>=",
> to pass in MAP fragments to an existing MAPFILE. I need to
> essentially add layers.
> Another thought I had (Ok, it's a bit odd, I'll admit . . .) would be
> to have MapServer build it's own MAPFILE as a TEMPLATE output, but I'm
> not coming up with a way immediately of passing the resulting MAPFILE
> to Mapserver in the end.
> bobb
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120416/76e6b2ad/attachment.html
