[mapserver-users] Passing a mapfile via CGI
Brent Fraser
bfraser at geoanalytic.com
Mon Apr 16 15:54:52 EDT 2012
I guess my solution would be to put the trails in a PostGIS table:
Trails:
id name geometry
1 trail A 234523452345
2 trail B 5879567876454
Use one map file with a FILTER "name='%trail_name%'". Now use
http://.../mapserv?trail_name="trail A" to have mapserver do the
variable substitution in the mapfile.
The bigger problem is generating the GUI layer list with the pointers to
the mapserver URLs. A script/database generated mapbook in GeoMoose, or
JavaScript list for use with OpenLayers, etc...
Best Regards,
Brent Fraser
On 4/16/2012 1:41 PM, Bob Basques wrote:
> Individual trails, one layer per GPS to allow user control of visibility.
> bobb
> >>> Brent Fraser <bfraser at geoanalytic.com> wrote:
> Well, in this application I don't care about a feature's real-world
> attributes (only the geometry and their feature "class"), so I'm able
> to pack all polygons into one table. I then join the polygon table to
> the feature class table to get the color, etc.
> Are you representing each GPS trail as a separate layer? So the user
> can turn individual trail on/off in a layer control?
> Best Regards,
> Brent Fraser
> On 4/16/2012 1:07 PM, Bob Basques wrote:
>> Hmm, interesting apporach, reminds me of my ealier days with Oracle
>> (before Oracle Spatial, where each feature type needed it's own table
>> structure . . . Have to do some more thinking on this one.
>> I'm trying to render a predefined list of layers (from the user) of a
>> set of GPS trails that are BEGIN and END indexed.
>> bobb
>> Bob,
>> What kinds of things are you trying to do with layers? Are the
>> layers vectors? Maybe there's a different way...
>> I'm in the midst of an implementation where the vectors are held in
>> PostGIS in three tables (point, line and polygon) and joined to a
>> "feature definition" table (to supply rendering values). I use one
>> map file with three layers (point, line, polygon) and pass a FILTER
>> variable to get my different layers which are then rendered.
>> Here's a snippet from the polygon layer:
>> CLASS
>> STYLE # Polygon Fill
>> SYMBOL [polyfill_symbol]
>> COLOR [polyfill_fillcolor]
>> ANGLE [polyfill_angle]
>> SIZE [polyfill_hatchgap] # e.g Hatching gap
>> WIDTH 1 # [polyfill_hatchthick] # Hatching
>> line thickness (column binding doesn't seem to work)
>> # OPACITY 50 # [attribute] # warning: there is
>> no OPACITY for LABEL so don't bother.
>> END
>> STYLE # Polygon Outline
>> SYMBOL [geom_symbol]
>> OUTLINECOLOR [geom_outcolor]
>> SIZE [geom_width] # for "simple" (?) symbols
>> WIDTH [geom_width] # for complex symbols
>> END # Style
>> TEXT ([gid])
>> LABEL
>> TYPE TRUETYPE
>> FONT [label_font]
>> ANTIALIAS TRUE
>> COLOR [label_fillcolor]
>> OUTLINECOLOR [label_outcolor]
>> BUFFER 1
>> POSITION cc #
>> [ul|uc|ur|cl|cc|cr|ll|lc|lr|auto]
>> PARTIALS TRUE
>> SIZE [label_height]
>> END # LABEL
>> END # class
>> While this method is suitable for rendering, it will be a problem if
>> you want store variables for use in an identify operation (or maybe
>> not; I wonder if a template name can be bound to a database column...)
>> Best Regards,
>> Brent Fraser
>> On 4/16/2012 10:22 AM, Bob Basques wrote:
>>> All,
>>> Did anything ever develop from this idea? I need to generate a
>>> variable length list of layers pro grammatically.
>>> I'm not finding anything from a quick search of things related to
>>> passing a MAPFILE via the CGI call. I want to be able to generate a
>>> MAPFILE, or chunks of it, on the fly. A possible solution (maybe
>>> scary security wise) would be to use a param like
>>> "INCLUDE_<someID>=", to pass in MAP fragments to an existing
>>> MAPFILE. I need to essentially add layers.
>>> Another thought I had (Ok, it's a bit odd, I'll admit . . .) would
>>> be to have MapServer build it's own MAPFILE as a TEMPLATE output,
>>> but I'm not coming up with a way immediately of passing the
>>> resulting MAPFILE to Mapserver in the end.
>>> bobb
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120416/983d80a2/attachment.html
