[mapserver-users] Passing a mapfile via CGI
Brent Fraser
bfraser at geoanalytic.com
Mon Apr 16 16:49:46 EDT 2012
It would make an interesting user extension in GeoMoose:
- Based on some GUI trigger (a button?), request a list of layers from
a URL (hey, a "getCapabilites" style service!), and populate/replace the
layer list in the catalog.
That would be cool...
Best Regards,
Brent Fraser
On 4/16/2012 2:07 PM, Bob Basques wrote:
> Yeah, the problem is, the list of GPSs is variable.
> It's all in POSTGIS now, and by GPS name.
> bobb
> >>> Brent Fraser <bfraser at geoanalytic.com> wrote:
> I guess my solution would be to put the trails in a PostGIS table:
> Trails:
> id name geometry
> 1 trail A 234523452345
> 2 trail B 5879567876454
> Use one map file with a FILTER "name='%trail_name%'". Now use
> http://.../mapserv?trail_name="trail A" to have mapserver do the
> variable substitution in the mapfile.
> The bigger problem is generating the GUI layer list with the pointers
> to the mapserver URLs. A script/database generated mapbook in
> GeoMoose, or JavaScript list for use with OpenLayers, etc...
> Best Regards,
> Brent Fraser
> On 4/16/2012 1:41 PM, Bob Basques wrote:
>> Individual trails, one layer per GPS to allow user control of
>> visibility.
>> bobb
>> Well, in this application I don't care about a feature's real-world
>> attributes (only the geometry and their feature "class"), so I'm
>> able to pack all polygons into one table. I then join the polygon
>> table to the feature class table to get the color, etc.
>> Are you representing each GPS trail as a separate layer? So the user
>> can turn individual trail on/off in a layer control?
>> Best Regards,
>> Brent Fraser
>> On 4/16/2012 1:07 PM, Bob Basques wrote:
>>> Hmm, interesting apporach, reminds me of my ealier days with Oracle
>>> (before Oracle Spatial, where each feature type needed it's own
>>> table structure . . . Have to do some more thinking on this one.
>>> I'm trying to render a predefined list of layers (from the user) of
>>> a set of GPS trails that are BEGIN and END indexed.
>>> bobb
>>> Bob,
>>> What kinds of things are you trying to do with layers? Are the
>>> layers vectors? Maybe there's a different way...
>>> I'm in the midst of an implementation where the vectors are held in
>>> PostGIS in three tables (point, line and polygon) and joined to a
>>> "feature definition" table (to supply rendering values). I use one
>>> map file with three layers (point, line, polygon) and pass a FILTER
>>> variable to get my different layers which are then rendered.
>>> Here's a snippet from the polygon layer:
>>> CLASS
>>> STYLE # Polygon Fill
>>> SYMBOL [polyfill_symbol]
>>> COLOR [polyfill_fillcolor]
>>> ANGLE [polyfill_angle]
>>> SIZE [polyfill_hatchgap] # e.g Hatching gap
>>> WIDTH 1 # [polyfill_hatchthick] # Hatching
>>> line thickness (column binding doesn't seem to work)
>>> # OPACITY 50 # [attribute] # warning: there is
>>> no OPACITY for LABEL so don't bother.
>>> END
>>> STYLE # Polygon Outline
>>> SYMBOL [geom_symbol]
>>> OUTLINECOLOR [geom_outcolor]
>>> SIZE [geom_width] # for "simple" (?) symbols
>>> WIDTH [geom_width] # for complex symbols
>>> END # Style
>>> TEXT ([gid])
>>> LABEL
>>> TYPE TRUETYPE
>>> FONT [label_font]
>>> ANTIALIAS TRUE
>>> COLOR [label_fillcolor]
>>> OUTLINECOLOR [label_outcolor]
>>> BUFFER 1
>>> POSITION cc #
>>> [ul|uc|ur|cl|cc|cr|ll|lc|lr|auto]
>>> PARTIALS TRUE
>>> SIZE [label_height]
>>> END # LABEL
>>> END # class
>>> While this method is suitable for rendering, it will be a problem if
>>> you want store variables for use in an identify operation (or maybe
>>> not; I wonder if a template name can be bound to a database column...)
>>> Best Regards,
>>> Brent Fraser
>>> On 4/16/2012 10:22 AM, Bob Basques wrote:
>>>> All,
>>>> Did anything ever develop from this idea? I need to generate a
>>>> variable length list of layers pro grammatically.
>>>> I'm not finding anything from a quick search of things related to
>>>> passing a MAPFILE via the CGI call. I want to be able to generate
>>>> a MAPFILE, or chunks of it, on the fly. A possible solution (maybe
>>>> scary security wise) would be to use a param like
>>>> "INCLUDE_<someID>=", to pass in MAP fragments to an existing
>>>> MAPFILE. I need to essentially add layers.
>>>> Another thought I had (Ok, it's a bit odd, I'll admit . . .) would
>>>> be to have MapServer build it's own MAPFILE as a TEMPLATE output,
>>>> but I'm not coming up with a way immediately of passing the
>>>> resulting MAPFILE to Mapserver in the end.
>>>> bobb
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120416/28cc408e/attachment-0001.html
