[mapserver-users] mapserver 5.6 CGI output GeoJSON format
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Apr 17 14:58:25 EDT 2012
So the problem with the coordinates is they are truncated or ??? Not having the spec handy what would the correct output be? There are
several arguments to the shpxy tag that will probably be of help. For example you might add:
[shpxy precision="6"]
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Li Quansheng
Sent: Tuesday, April 17, 2012 11:18 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] mapserver 5.6 CGI output GeoJSON format
hi guys,
I installed FGS 5.6.3 on my VM to do some studying, these days I want to add WFS layer to my applyaction via openlayers, and I want to do some WFS query to output GeoJSON, I do my best, now,there is one problem I can't figure out.
my mapfile: (mapserver 5.6)
OUTPUTFORMAT
NAME "geojson"
DRIVER "TEMPLATE"
MIMETYPE "application/json; subtype=geojson"
FORMATOPTION "FILE=xj1JSON.tmpl"
END
METADATA
'ows_title' 'XJ-MAP' #OWS (OGC Web Services)
'ows_onlineresource'
'http://192.168.207.100/cgi-bin/mapserv?map=/opt/fgs/www/htdocs/xj1/xj1.map'
'ows_srs' 'EPSG:4326'
'wms_tile' 'xjmap'
'wms_onlineresource'
'wms_srs' 'EPSG:4326 EPSG:900913'
"wfs_title" "xjmap"
"wfs_onlineresource"
"http://192.168.207.100/cgin-bin/mapserv?map=/opt/fgs/www/htdocs/xj1/xj1.map&"
"wfs_srs" "EPSG:4326 EPSG:900913" ## Recommended
"wfs_abstract" "xjmap WFS service." ## Recommended
"wfs_enable_request" "*" # necessary,"*" enables all requests
"wfs_encoding" "UTF-8"
END
LAYER
NAME 'tielu'
TYPE LINE
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
EXTENT 70.409351 33.963843 99.420299 49.549665 CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=xj1 user=xxx password=xxx"
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "the_geom from tielu"
METADATA
'ows_title' 'tielu'
"wfs_title" "tielu" ##REQUIRED
"wfs_srs" "EPSG:4326" ## REQUIRED
"wfs_featureid" "gid"
#"wfs_getfeature_formatlist" "geojson" # mapserver 6.0 support
"gml_include_items" "all" ## Optional (serves all attributes for layer)
"gml_featureid" "gid" ## REQUIRED
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'tielu'
STYLE
WIDTH 0.91
COLOR 164 229 51
END
END
END
the GeoJson outputformat template file xj1JSON.tmpl // mapserver template [resultset layer=tielu] {
"type": "FeatureCollection",
"features": [
[feature limit=-1 feature trimlast=","]
"type": "Feature",
"id": "[gid]",
"geometry": {
"type": "MultiLineString",
"coordinates": [
"coordinates": [[[shpxy]]]
"properties": {
"gid": "[gid]",
"type": "[type]",
"name": "[name]"
[/feature]
[/resultset]
I want to output the "tielu" multiline layer , I can success execute the http request, http://192.168.207.100/cgi-bin/mapserv?map=/opt/fgs/www/htdocs/xj1/xj1.map&layer=tielu&mode=nquery&qformat=geojson
, It seemed that all the GeoJSON output is perfect except the output coordinates of the colum the_geom.
the output is as flowings:
"features": [
"type": "Feature",
"id": "1",
"geometry": {
"coordinates": [
"coordinates": [[84,42 84,42 84,42 84,42 83,42 83,42 83,42 83,42
83,42 83,42]] //there is sth wrong here!
"properties": {
"gid": "1",
"type": "70",
"name": "name111"
I think sth wrong in my template file about "coordinates":
[[[shpxy]]], I do many google searching,try my best to correct the file,I try
"coordinates": [[LONG], [LAT]] etc,
, but I failed, Could anyone give me some advice, thank you very much!
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
