[mapserver-users] RE: Possible bug: Cairo/PDF output labels
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Apr 20 06:50:51 EDT 2012
I have never observed such an error with the my Super easy WMS server. You seem to be on Windows so it will be easy for you to make a test install and do some comparisons. Read document http://latuviitta.org/documents/Super_easy_WMS_server.pdf first.
-Jukka Rahkonen-
Frost89 wrote:
After a quick test it seems to work with a constant of 45.
This doesn't solve our prooblem though. The most important for us, is the ANGLE follow on the roads.
It draws bitmaps fine, its just the PDF that fails.
The build is made by Tamas Szekeres' from here: vbkto.dyndns.org/sdk<http://vbkto.dyndns.org/sdk/>.
The OUTPUTFORMAT is generated from code, but it would look like this:
OUTPUTFORMAT
NAME "WGK_PDF"
DRIVER CAIRO/PDF
MIMETYPE "application/x-pdf"
IMAGEMODE RGB
EXTENSION "pdf"
TRANSPARENT OFF
END
View this message in context: RE: Possible bug: Cairo/PDF output labels<http://osgeo-org.1560.n6.nabble.com/Possible-bug-Cairo-PDF-output-labels-tp4894039p4901381.html>
Sent from the Mapserver - User mailing list archive<http://osgeo-org.1560.n6.nabble.com/Mapserver-User-f4226646.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120420/63abbfea/attachment.html
