[mapserver-users] Re: pdf vector output in 6.02
frequens
frequens at gmail.com
Mon Apr 23 02:37:07 EDT 2012
Weird.To add a little:
With 5.6.5 I am able to get a vector pdf using mapserv or shp2img,
mapscript dies without message.
With 6.0.2 in all three cases (shp2img, mapserv, mapscript) the pdf
gets created, yet contains only the rendered raster image of the
vector layers.
Why this fallback to raster rendering, is this something supposed to
happen? All the underlying libraries are the same.
Any hints?
BR
frequens
On Fri, Apr 20, 2012 at 11:50 PM, frequens <frequens at gmail.com> wrote:
> Hi all,
> I am having trouble producing a high quality vector output pdf with
> 6.02 php mapscript (same trouble using shp2img)
> Cairo is enabled, the pdf file even gets created, but contains only a
> raster image?
> Pdf output is enabled:
> IMAGETYPE PDF
> and
> OUTPUTFORMAT
> NAME "pdf"
> DRIVER CAIRO/PDF
> MIMETYPE "application/x-pdf"
> IMAGEMODE RGB
> EXTENSION "pdf"
> END
> Since the mapserver documentation on pdf creation is rather archaic,
> any help (a stripped version of someone's mapfile?) would be
> appreciated!
> My cairo library is rather old also: 1.4.10. Might this have any influence?
> Many thanks in advance,
> frequens
