[mapserver-users] Re: pdf vector output in 6.02
Havard Tveite
havard.tveite at umb.no
Mon Apr 23 04:03:26 EDT 2012
Seems to work here. I get vector PDF output using 6.0.2 on Debian.
Håvard
On 4/23/2012 9:17 AM, Rahkonen Jukka wrote:
> Hi,
> PDF output works for me on Windows (MS4W) but I seem to have problems with Linux and Mapserver 6.0.1 also. This one gives HTTP 500 Internal error message and on the server side there seems to occur a segfault
> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=469&HEIGHT=354&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=385063.18278820685,6671589.90189085,385461.47239845013,6671890.529869583&SRS=EPSG:3067&STYLES=
> Same with SVG output. Png etc. works fine. I have the same outputformat as you.
> -Jukka Rahkonen-
> frequens wrote:
>> Weird.To add a little:
>> With 5.6.5 I am able to get a vector pdf using mapserv or shp2img,
>> mapscript dies without message.
>> With 6.0.2 in all three cases (shp2img, mapserv, mapscript) the pdf
>> gets created, yet contains only the rendered raster image of the
>> vector layers.
>> Why this fallback to raster rendering, is this something supposed to
>> happen? All the underlying libraries are the same.
>> Any hints?
>> BR
>> frequens
>> On Fri, Apr 20, 2012 at 11:50 PM, frequens<frequens at gmail.com> wrote:
>>> Hi all,
>>> I am having trouble producing a high quality vector output pdf with
>>> 6.02 php mapscript (same trouble using shp2img)
>>> Cairo is enabled, the pdf file even gets created, but
>> contains only a
>>> raster image?
>>> Pdf output is enabled:
>>> IMAGETYPE PDF
>>> and
>>> OUTPUTFORMAT
>>> NAME "pdf"
>>> DRIVER CAIRO/PDF
>>> MIMETYPE "application/x-pdf"
>>> IMAGEMODE RGB
>>> EXTENSION "pdf"
>>> END
>>> Since the mapserver documentation on pdf creation is rather archaic,
>>> any help (a stripped version of someone's mapfile?) would be
>>> appreciated!
>>> My cairo library is rather old also: 1.4.10. Might this
>> have any influence?
>>> Many thanks in advance,
>>> frequens
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
