[mapserver-users] Mapserver MS4W PostGIS 2.0.0
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Apr 23 16:56:54 EDT 2012
Thanks, Brent.
That answers the question. Will look at using "legacy.sql" on the PostGIS
side rather than reverting to an older version until such times as
Mapserver/MS4W catches up.
Many thanks.
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: 23 April 2012 21:52
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver MS4W PostGIS 2.0.0
https://github.com/mapserver/mapserver/issues/4186
Best Regards,
Brent Fraser
On 4/23/2012 2:46 PM, Donald Kerr wrote:
> John,
> I've just installed PostGIS 2.0.0 and I'm getting:
> msDrawMap(): Image handling error. Failed to draw layer named 'ABC'.
> msPostGISLayerWhichShapes(): Query error. Error executing query:
> ERROR: function geomfromtext(unknown, integer) does not exist LINE 1:
> ...as geom,"toid" from ABC where geom&& GeomFromTe... ^ HINT: No
> function matches the given name and argument types. You might need to
> add explicit type casts.
> > From what I can make out, it appears that "geomfromtext" has changed
> > name in
> PostGIS to "ST_GeomFromText". I think "geomfromtext" is hard codeed in
> MapServer version 6.0.2 (MS4W 3.0.4).
> Many thanks.
> Regards,
> Donald
> From: John Callahan [mailto:john.callahan at udel.edu]
> Sent: 23 April 2012 21:23
> To: Donald Kerr
> I've been using MS4W for a while and the latest versions seem to
> support Postgis 2.0 just fine.
> - John
> John Callahan, Research Scientist
> Delaware Geological Survey, University of Delaware
> URL: http://www.dgs.udel.edu
> On Mon, Apr 23, 2012 at 3:27 PM, Donald Kerr<donald.kerr at dkerr.co.uk>
> wrote:
> Can anyone give me an idea of timescales for the release of PostGIS
> 2.0.0 support in Mapserver and then MS4W please?
> Many thanks.
> Regards,
> Donald
