[mapserver-users] Really slow map creation from POSTGIS DB
Julien Cigar
jcigar at ulb.ac.be
Sat Apr 28 14:22:51 EDT 2012
On 04/28/2012 14:44, Matt McClelland wrote:
> Hi All
> I have a set of contours in a SHP file
> If I point my map file to the SHP file I can generate a WMS image in
> under 1 second
> Shp file is just shy of 200MB
> I then use shp2pgsql to load the same dataset into the DB
> I added an index for the_geom
> And am requesting the data in the mapfile using the same EPSG
> The map draws correclty but is now taking about 30secs when using the DB.
are you sure your postgresql is well configured ? can you pastebin your
postgresql.conf and some details about your configuration ?
> Any ideas on how to make it faster.
> Thanks
> Matt :)
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120428/c4c8917a/attachment.html
