[mapserver-users] help -- PostGIS data not displaying as expected, works with shapefiles though!
Ben Madin lists at remoteinformation.com.au
Mon Apr 30 23:04:16 PDT 2012
Sean,
On 01/05/2012, at 12:50 PM, Sean Twomey <stwomey at hotmail.com> wrote:
> I get the following error when I execute the map file at the bottom of this message:
> msDrawMap(): Image handling error. Failed to draw layer named 'nationalPark'. msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR: Operation on two geometries with different SRIDs
> I can get this to work when its just a shapefile, but it doesn't work when its coming from PostGIS.  I am using Mapserver 6.0.2 with postgresql 9.1 and postgis 1.5.3
It sounds like maybe your shape file has been imported with a different geometry to that which you are telling it in your request:
   DATA 'the_geom FROM "nationalPark" USING UNIQUE gid USING srid=3005'
would suggest that the data is in the database in the EPSG:3005 (British Columbia Albers) projection. Check that it is …?
cheers
Ben
More information about the MapServer-users mailing list
