[mapserver-users] Antwort: Re: Mapserver 6: Oracle & layerObj.queryByIndex
umn-ms at hydrotec.de
Thu Aug 2 01:34:30 PDT 2012
Hi Thomas
The "Single Query Issue" is complex. I'll try to break this one down,
because I think this one seams to be
quite obvious and the code is unchanged in 6.2.0 beta1
DESCRIPTION:
The function "msQueryByIndex(mapObj* map)" has a local variable "resultObj
record;".
The field "record.resultindex" is never initialized.
In this function the uninitialized record-variable is passed to
"msLayerGetShape(...,&record)".
The Oracle-Implementation "msOracleSpatialLayerGetShape" of the
msLayerGetShape-Function
evaluates the uninitialized "record.resultindex".
In my case "msOracleSpatialLayerGetShape" threw an error.
SOLUTION (Suggestion):
In msQueryByIndex resultObj record should be initialized.
At least:
record.resultindex = -1;
>From a users point of view this error rises sporadic.
Benedikt
PS: I have some more frustrating issues of this kind. But this is the only
one I can desribe precisly.
thomas bonfort <thomas.bonfort at gmail.com> schrieb am 02.08.2012 09:16:52:
> 02.08.2012 09:23
> An
> Kopie
> MapserverList OSGEO <mapserver-users at lists.osgeo.org>
> Thema
> Re: [mapserver-users] Mapserver 6: Oracle & layerObj.queryByIndex
> Hi,
> Issues https://github.com/mapserver/mapserver/issues/4238 and
> https://github.com/mapserver/mapserver/issues/4076 seem closely
> related. I'm not a query expert, but I do know that part of the code
> has been quite heavily worked on for 6.2, any chance you could try
> with that version and confirm if it has been fixed or not?
> regards,
> thomas
> On Wed, Aug 1, 2012 at 4:51 PM, <umn-ms at hydrotec.de> wrote:
> > Hi
> > I'm porting an Java-Mapscript-application from Mapserver 5.4 to
Mapserver
> > 6.0.
> > Data is stored in Oracle-Saptial.
> > I have a problem with layerObj.queryByIndex.
> > To illustrate, i use a small Java-Testprogram:
> > import edu.umn.gis.mapscript.layerObj;
> > import edu.umn.gis.mapscript.mapObj;
> > import edu.umn.gis.mapscript.shapeObj;
> > public class QueryExtent {
> > public static void main(String argv []) {
> > mapObj map = new mapObj("java_test\\umn.map");
> > layerObj l = map.getLayerByName("Gemeinden"); // Gemeinden is
> > Oracle-Spatial-Layer
> > int i = l.queryByIndex(map, 0, 2, 0);
> > System.out.println(i);
> > This program prints 1 - saying, that the queryByIndex-call was not
> > successfull.
> > Logfile: msOracleSpatialLayerGetShape(): OracleSpatial error.
> > msOracleSpatialLayerGetShape record out of range
> > By additional debugging I saw: In msOracleSpatialLayerGetShape
Mapserver
> > runs into the "if (resultindex >= 0)"-branch.
> > In my case resultindex is an extra-ordinary big integer-number.
> > I don't really understand ths query-layer-code in Mapserver. But I
think in
> > my case resultindex should by -1 and that Mapserver
> > should initialize resultindex automatically.
> > Therfore I changed code:
> > int msQueryByIndex(mapObj *map) {
> > resultObj record;
> > record.resultindex = -1; // added line.
> > Is the fix correct or should I use Mapscript differently?
> > Benedikt
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
