[mapserver-users] Using spatialite with mapserver
Andrea Peri
aperi2007 at gmail.com
Fri Aug 3 01:05:52 PDT 2012
>This looks like an OGR bug, I have correct info in views_geometry_columns
(refering to
>geom2 of the main table) and in geometry_columns (both geom1 and geom2 has
>records).
>For now, forget multiple geometries and create new single geometry tables
and enjoy the
>speed of Spatialite and Mapserver.
>-Jukka Rahkonen-
thx Jukka,
Is an unpleasant situation this ogr bug.
My table af many fields attribute . it is about 15 Gbyte (gasp!)
so split it in two tables so separate the geometries is not a beatiful
action. :)
But I'm notice another question.
Infact after remove the secondary geometries (sigh), I can see that there
is a strange liit due to numer of elements.
Infact Mapserver work with this sql:
DATA 'SELECT field1, field2, field3, geometry from table LIMIT 20000'
but don't work with this other sql:
DATA 'SELECT field1, field2, field3, geometry from table LIMIT 200000'
Seem there is a max number of elements retrieval.
The strange is that with this second sql MapServer don't do nothing.
Simply it end its work without generate no map.
No error log report is write.
Perhaps there is a setting to say how much memory mapserver (or ogr) must
use for resultset from DB ?
Thx.
2012/8/2 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi again,
> Tried what ogrinfo sees in case of two geometries. It does not look good.
> FID Column = rowid
> Geometry Column = geom1
> geom2: Binary (0.0)
> OGRFeature(test2):1
> geom2 (Binary) =
> 0001110F0000958B843BA9EC354126C76C9BD95A5A41958B843BA9EC35412
> 6C76C9BD95A...
> POINT (1436841.2324912299 6908774.4285142776)
> OGRFeature(test2):2
> geom2 (Binary) =
> 0001110F000081AE1AFBAEEF3541FB1B8FFA035B5A4181AE1AFBAEEF3541F
> B1B8FFA035B...
> POINT (1437614.9808758798 6908943.9149846984)
> So that means than only the first geometry can be user with OGR. Next I
> tried to create a spatial view with spatialite-gui by selecting only geom2
> into the view. This fails too
> D:\ms4w\data>ogrinfo berlin.sqlite test3
> INFO: Open of `berlin.sqlite'
> using driver `SQLite' successful.
> ERROR 1: Underlying layer test2 for view test3 has not expected geometry
> column
> name (geom1 instead of geom2)
> Layer name: test3
> Geometry: Unknown (any)
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Column = ROWID
> Geometry Column = geom2
> (refering to geom2 of the main table) and in geometry_columns (both geom1
> and geom2 has records).
> and enjoy the speed of Spatialite and Mapserver.
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] käyttäjän
> Rahkonen Jukka [Jukka.Rahkonen at mmmtike.fi] puolesta
> Lähetetty: 3. elokuuta 2012 0:27
> Vastaanottaja: Andrea Peri; mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Using spatialite with mapserver
> Hi,
> The SELECT alternative works fine for me but I do not have multiple
> geometries. I made a very fast test on Spatialite side and it seems to be
> possible to run "Recover geometry column" and "Create spatial index" for
> multiple geometries but I did not test the result with Mapserver.
> I would recommend you to check first your geometry_columns table and see
> it there is a line for the geometry you want to use and if spatial index is
> OK. If they are OK make a simplified test. Create a single geometry table as
> CREATE table test as
> SELECT geom1, attr1... FROM...
> Do "Recover geometry column" and "Create spatial index" things for the new
> table and have a try with Mapserver.
> GDAL version must be 1.9 or higher or things will be far too slow.
> This document may also be useful for you
> http://latuviitta.org/documents/Super_easy_WMS_server.pdf
> -Jukka Rahkonen-
> mapserver-users-bounces at lists.osgeo.org] käyttäjän Andrea Peri [
> aperi2007 at gmail.com] puolesta
> Lähetetty: 2. elokuuta 2012 23:03
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Using spatialite with mapserver
> Hi,
> I'm try-ing to use spatialite with mapserver.
> is this mapfile configuration ok for spatialite ?
> CONNECTIONTYPE OGR
> CONNECTION '/..path-to../spatialite_file.sqlite'
> DATA 'SELECT field1, field2, field3, geometry from table'
> It seem don't work.
> Instead work perfectly this other configuration:
> CONNECTIONTYPE OGR
> CONNECTION
> '/home/vector/vettoriali/db_catasto/regione_toscana/adt_toscana.sqlite'
> DATA 'table'
> Unfortunately this second configuration don't allow to choose the geometry
> field , necessary when spatialite table as two or more geometry field.
> Thx,
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120803/5695e1d6/attachment-0001.html>
