[mapserver-users] MapServer configure question with PHP/MapScript Module
李杨
gisyangli at gmail.com
Tue Aug 7 07:36:07 PDT 2012
Hi, Everyone.
I want to compile mapserver from source.
Both the mapserver readme.configure file and the instuctionpost here (
http://www.mapserver.org/installation/php.html) tell me
"pass the *–with-php=DIR* argument to the configure script",
As the guide say, the "DIR" will be PHP sourcecode folder, but in my
ubuntu 12.04 platform, it take aPHP5, no need to compile PHP from source.
So I am confused, which folder should I assign?
by the way, I "locate php5" on the shell and got the result below:
/etc/php5
/etc/apache2/mods-available/php5.conf
/etc/apache2/mods-available/php5.load
/etc/apache2/mods-enabled/php5.conf
/etc/apache2/mods-enabled/php5.load
/etc/apparmor.d/abstractions/php5
/etc/cron.d/php5
/etc/php5/apache2
/etc/php5/cli
/etc/php5/conf.d
/etc/php5/apache2/conf.d
/etc/php5/apache2/php.ini
/etc/php5/cli/conf.d
/etc/php5/cli/php.ini
/etc/php5/conf.d/curl.ini
/etc/php5/conf.d/mysql.ini
/etc/php5/conf.d/mysqli.ini
/etc/php5/conf.d/pdo.ini
/etc/php5/conf.d/pdo_mysql.ini
/usr/bin/php5
/usr/lib/php5
/usr/lib/apache2/modules/libphp5.so
/usr/lib/php5/20090626
/usr/lib/php5/libexec
/usr/lib/php5/maxlifetime
/usr/lib/php5/20090626/curl.so
/usr/lib/php5/20090626/mysql.so
/usr/lib/php5/20090626/mysqli.so
/usr/lib/php5/20090626/pdo.so
/usr/lib/php5/20090626/pdo_mysql.so
/usr/share/php5
/usr/share/apport/package-hooks/source_php5.py
/usr/share/doc/libapache2-mod-php5
/usr/share/doc/php5-cli
/usr/share/doc/php5-common
/usr/share/doc/php5-curl
/usr/share/doc/php5-mysql
/usr/share/doc/php5-common/CODING_STANDARDS.gz
/usr/share/doc/php5-common/CREDITS
/usr/share/doc/php5-common/EXTENSIONS.gz
/usr/share/doc/php5-common/NEWS.Debian.gz
/usr/share/doc/php5-common/README.Debian.gz
/usr/share/doc/php5-common/README.Debian.security
/usr/share/doc/php5-common/README.EXT_SKEL.gz
/usr/share/doc/php5-common/README.PHP4-TO-PHP5-THIN-CHANGES.gz
/usr/share/doc/php5-common/README.SELF-CONTAINED-EXTENSIONS.gz
/usr/share/doc/php5-common/README.SVN-RULES.gz
/usr/share/doc/php5-common/README.Zeus.gz
/usr/share/doc/php5-common/TODO.gz
/usr/share/doc/php5-common/changelog.Debian.gz
/usr/share/doc/php5-common/copyright
/usr/share/doc/php5-common/examples
/usr/share/doc/php5-common/test-results.txt.gz
/usr/share/doc/php5-common/examples/php.ini-development
/usr/share/lintian/overrides/libapache2-mod-php5
/usr/share/lintian/overrides/php5-cli
/usr/share/lintian/overrides/php5-common
/usr/share/man/man1/php5.1.gz
/usr/share/php5/php.ini-production
/usr/share/php5/php.ini-production-dist
/usr/share/php5/php.ini-production.cli
/var/cache/apt/archives/libapache2-mod-php5_5.3.10-1ubuntu3.2_amd64.deb
/var/cache/apt/archives/php5-cli_5.3.10-1ubuntu3.2_amd64.deb
/var/cache/apt/archives/php5-common_5.3.10-1ubuntu3.2_amd64.deb
/var/cache/apt/archives/php5-curl_5.3.10-1ubuntu3.2_amd64.deb
/var/cache/apt/archives/php5-mysql_5.3.10-1ubuntu3.2_amd64.deb
/var/lib/php5
/var/lib/dpkg/info/libapache2-mod-php5.conffiles
/var/lib/dpkg/info/libapache2-mod-php5.list
/var/lib/dpkg/info/libapache2-mod-php5.md5sums
/var/lib/dpkg/info/libapache2-mod-php5.postinst
/var/lib/dpkg/info/libapache2-mod-php5.postrm
/var/lib/dpkg/info/libapache2-mod-php5.prerm
/var/lib/dpkg/info/libapache2-mod-php5.triggers
/var/lib/dpkg/info/php5-cli.list
/var/lib/dpkg/info/php5-cli.md5sums
/var/lib/dpkg/info/php5-cli.postinst
/var/lib/dpkg/info/php5-cli.postrm
/var/lib/dpkg/info/php5-cli.prerm
/var/lib/dpkg/info/php5-common.conffiles
/var/lib/dpkg/info/php5-common.list
/var/lib/dpkg/info/php5-common.md5sums
/var/lib/dpkg/info/php5-common.postrm
/var/lib/dpkg/info/php5-curl.conffiles
/var/lib/dpkg/info/php5-curl.list
/var/lib/dpkg/info/php5-curl.md5sums
/var/lib/dpkg/info/php5-mysql.conffiles
/var/lib/dpkg/info/php5-mysql.list
/var/lib/dpkg/info/php5-mysql.md5sums
Best Regards,
Yang Li
GIS Developer
P.R.China
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120807/066ddcff/attachment.html>
