[mapserver-users] Using spatialite with mapserver
Andrea Peri
aperi2007 at gmail.com
Fri Aug 3 16:19:06 PDT 2012
Hi
the 200.000 limit was effectively an invalid geometries,
thx.
About the multi-geometry question.
I'm try-ing the option
DATA 'table(geometry)'
but I have a secondary problem.
Infact this sintax seem deny the access to other fields.
So was impossible to set a label.
I'm missing something ?
Thx,
Andrea
2012/8/3 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,****
> I correct myself, support for multiple geometry columns is not a bug but a
> missing feature. I just wrote about it into GDAL-dev list. Let’s see what
> happens.****
> When it comes to error with ‘limit 200000’ I believe that the real problem
> is in a different place. I bet that there is a faulty geometry somewhere
> between 20000 and 200000 geometries. In that case OGR throws an error and
> stops. For Mapserver users it would be extremely much better if OGR in such
> case just skips the error and continues. I know the issue because it is
> common with OpenSteetMap polygons. As a workaround I have myself just
> deleted all the non-valid geometries from Spatialite with “delete from
> table where ST_IsValid(geometry)=0”.****
> -Jukka Rahkonen-****
> Andrea Peri wrote:****
> >This looks like an OGR bug, I have correct info in views_geometry_columns
> (refering to
> >geom2 of the main table) and in geometry_columns (both geom1 and geom2
> has
> >records).
> >For now, forget multiple geometries and create new single geometry tables
> and enjoy the
> >speed of Spatialite and Mapserver.
> >-Jukka Rahkonen-
> thx Jukka,
> Is an unpleasant situation this ogr bug.
> My table af many fields attribute . it is about 15 Gbyte (gasp!)
> so split it in two tables so separate the geometries is not a beatiful
> action. :)
> But I'm notice another question.
> Infact after remove the secondary geometries (sigh), I can see that there
> is a strange liit due to numer of elements.
> Infact Mapserver work with this sql:
> DATA 'SELECT field1, field2, field3, geometry from table LIMIT 20000'
> but don't work with this other sql:
> DATA 'SELECT field1, field2, field3, geometry from table LIMIT 200000'
> Seem there is a max number of elements retrieval.
> The strange is that with this second sql MapServer don't do nothing.
> Simply it end its work without generate no map.
> No error log report is write.
> Perhaps there is a setting to say how much memory mapserver (or ogr) must
> use for resultset from DB ?
> Thx.
> 2012/8/2 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>****
> Hi again,
> Tried what ogrinfo sees in case of two geometries. It does not look good.
> FID Column = rowid
> Geometry Column = geom1
> geom2: Binary (0.0)
> OGRFeature(test2):1
> geom2 (Binary) =
> 0001110F0000958B843BA9EC354126C76C9BD95A5A41958B843BA9EC35412
> 6C76C9BD95A...
> POINT (1436841.2324912299 6908774.4285142776)
> OGRFeature(test2):2
> geom2 (Binary) =
> 0001110F000081AE1AFBAEEF3541FB1B8FFA035B5A4181AE1AFBAEEF3541F
> B1B8FFA035B...
> POINT (1437614.9808758798 6908943.9149846984)
> So that means than only the first geometry can be user with OGR. Next I
> tried to create a spatial view with spatialite-gui by selecting only geom2
> into the view. This fails too
> D:\ms4w\data>ogrinfo berlin.sqlite test3
> INFO: Open of `berlin.sqlite'
> using driver `SQLite' successful.
> ERROR 1: Underlying layer test2 for view test3 has not expected geometry
> column
> name (geom1 instead of geom2)
> Layer name: test3
> Geometry: Unknown (any)
> Feature Count: 0
> Layer SRS WKT:
> (unknown)
> FID Column = ROWID
> Geometry Column = geom2
> (refering to geom2 of the main table) and in geometry_columns (both geom1
> and geom2 has records).
> and enjoy the speed of Spatialite and Mapserver.
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] käyttäjän
> Rahkonen Jukka [Jukka.Rahkonen at mmmtike.fi] puolesta
> Lähetetty: 3. elokuuta 2012 0:27
> Vastaanottaja: Andrea Peri; mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Using spatialite with mapserver****
> Hi,
> The SELECT alternative works fine for me but I do not have multiple
> geometries. I made a very fast test on Spatialite side and it seems to be
> possible to run "Recover geometry column" and "Create spatial index" for
> multiple geometries but I did not test the result with Mapserver.
> I would recommend you to check first your geometry_columns table and see
> it there is a line for the geometry you want to use and if spatial index is
> OK. If they are OK make a simplified test. Create a single geometry table as
> CREATE table test as
> SELECT geom1, attr1... FROM...
> Do "Recover geometry column" and "Create spatial index" things for the new
> table and have a try with Mapserver.
> GDAL version must be 1.9 or higher or things will be far too slow.
> This document may also be useful for you
> http://latuviitta.org/documents/Super_easy_WMS_server.pdf
> -Jukka Rahkonen-
> mapserver-users-bounces at lists.osgeo.org] käyttäjän Andrea Peri [
> aperi2007 at gmail.com] puolesta
> Lähetetty: 2. elokuuta 2012 23:03
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Using spatialite with mapserver
> Hi,
> I'm try-ing to use spatialite with mapserver.
> is this mapfile configuration ok for spatialite ?
> CONNECTIONTYPE OGR
> CONNECTION '/..path-to../spatialite_file.sqlite'
> DATA 'SELECT field1, field2, field3, geometry from table'
> It seem don't work.
> Instead work perfectly this other configuration:
> CONNECTIONTYPE OGR
> CONNECTION
> '/home/vector/vettoriali/db_catasto/regione_toscana/adt_toscana.sqlite'
> DATA 'table'
> Unfortunately this second configuration don't allow to choose the geometry
> field , necessary when spatialite table as two or more geometry field.
> Thx,
> Andrea Peri
> qwerty àèìòù
> http://lists.osgeo.org/mailman/listinfo/mapserver-users****
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120804/4ebe0c5c/attachment-0001.html>
