[mapserver-users] Spatialite tables with multiple geometry columns
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sat Aug 4 06:17:22 PDT 2012
I can't test myself right now because I cannot access gisinternals.com for getting a fresh Windows build. However, I for using geom2 of a multigeom table would try with
DATA 'SELECT geom2,attr1,attr2.... FROM table'
You can also create a spatial view which selects geom2 on the Spatialite side and use then simply
DATA 'view'
Another advantage in creating spatial view is that they can be used directly in QGis once it will have fresh enough GDAL version. I am remembering that QGis cannot make layers from Spatialite with SQL queries.
-Jukka Rahkonen-
Andrea Peri wrote:
> Hi Roualt,
> thx for patch,
> I'm go to test it.
> Just a question to understand how use it.
> the sintax 'TABLE(GEOMETRY)' should return also the attributes from table or only the geometry without attribute ?
> regards,
Andrea Peri
qwerty àèìòù
