[mapserver-users] transitioning between mapservers - port forwarding
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Aug 8 09:28:17 PDT 2012
Hello,
I would like to see if I can run both MS4W 3.0 beta 7 (mapserver 5) and MS4W 3.x (mapserver 6).
Background:
Currently I am using an older version of MS4W to host our GeoMOOSE 2.2 applications, which are not compatible with the newer versions of MS4W. In addition to using the older MS4W application, I would also like to add a new version of MS4W. This way I can transition to GeoMOOSE 2.6 (which runs on the newer MS4W distribution), and take advantage of MapCache without having to completely change all the applications at once. The server I have has two partitions and by renaming the service in Apache-install.bat I can run both both the old MS4W applications and the new MS4W applications.
Questions:
Has anyone else done anything similar to this?
Is there a way to only use one IP address or port? For example could I make: http://mysite/myOldApp go to the old version of MS4W and http://mysite/myNewApp go to the new version of MS4W?
Thanks for any ideas
Mark Volz
GIS Specialist
