[mapserver-users] issue when upgrading layer from 5.x to 6.0
Mark Volz
MarkVolz at co.lyon.mn.us
Wed Aug 8 13:50:39 PDT 2012
Hello,
Thank you for all your replies on helping me figure out why a mapfile was working in 5.x and not 6.x. It turns out that the problem was with an included symbol.sym file. I realized that I am not even using this file on this particular map so I removed the reference. So now everything is working, and this particular map will now run a little faster. As Astrid mentioned I will take a closer look at the migration guide when I move other maps over that depend on the included symbol file.
Thanks again
Mark Volz
> Message: 1
> Date: Wed, 8 Aug 2012 06:07:25 +0000
> From: "Lime, Steve D (DNR)" <Steve.Lime at state.mn.us>
> To: Mark Volz <MarkVolz at co.lyon.mn.us>,
> "mapserver-users at lists.osgeo.org" <mapserver-
> users at lists.osgeo.org>
> Subject: Re: [mapserver-users] issue when upgrading layer from 5.x to
> 6.0
> Message-ID:
> <C549F0496453D842B4DD71AC8188DDC51E66F2 at 055-CH1MPN1-
> 042.055d.mgd.msft.net>
> Content-Type: text/plain; charset="us-ascii"
> Nothing jumps out. Are you using INCLUDES or and external symbol file?
> Wonder if the line number is off or referencing another file.
> Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-
> bounces at lists.osgeo.org] on behalf of Mark Volz [MarkVolz at co.lyon.mn.us]
> Sent: Tuesday, August 07, 2012 10:04 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] issue when upgrading layer from 5.x to 6.0
> Hello,
> I am upgrading a mapfile from Mapserver 5.x to Mapserver 6.0. This map
> works fine in 5.x, however it crashes on the "STYLE" line. If anyone sees
> anything wrong with this layer let me know.
> LAYER
> NAME 'Townships'
> TYPE POLYGON
> DATA './LyonCounty/Boundaries/Townships'
> MINSCALEDENOM 15000
> STATUS DEFAULT
> TRANSPARENCY 100
> CLASSITEM "COLOR"
> CLASS
> NAME 'Townships'
> EXPRESSION 'T'
> STYLE ####### THIS IS WHERE MS CRASHED DUE TO "Unknown
> identifier. Parsing error near (STYLE):(line 109)"
> #SYMBOL 'hatch-test'
> COLOR 170 170 170
> SIZE 2
> WIDTH 1
> END #STYLE
> END #class
> END # townships layer
> Thank you for your help
> Mark
