[mapserver-users] R: Re: oraclespatial connection
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Mon Aug 20 09:10:12 PDT 2012
Hmm,
You can't use that statement directly in sqlplus
You could use
SELECT OBJECTID_1,rownum, SHAPE FROM PSITDATA.COMUNI WHERE SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, :srid, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),sdo_ordinate_array(minx, miny, maxx, maxy) ),'querytype=window') = 'TRUE'
And put in the minx,miny,maxx, maxy values from the debug log to verify its all working properly.
From: Michele De Santis <tape2m at virgilio.it<mailto:tape2m at virgilio.it>>
Reply-To: Michele De Santis <tape2m at virgilio.it<mailto:tape2m at virgilio.it>>
Date: Mon, 20 Aug 2012 18:00:53 +0200
To: Michael Smith <michael.smith at erdc.dren.mil<mailto:michael.smith at erdc.dren.mil>>, "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: R: Re: [mapserver-users] oraclespatial connection
Thank you Michael,
I tried without version but with the same result.
Michele
----Messaggio originale----
Da: Michael.Smith at erdc.dren.mil<mailto:Michael.Smith at erdc.dren.mil>
Data: 20-ago-2012 17.53
A: "Michele De Santis"<tape2m at virgilio.it<mailto:tape2m at virgilio.it>>, "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>"<mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Ogg: Re: [mapserver-users] oraclespatial connection
Michele,
Try with
DATA "SHAPE FROM PSITDATA.COMUNI USING SRID 32633"
The VERSION 10g part doesn't need to be used anymore.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
Date: Mon, 20 Aug 2012 17:37:33 +0200
To: <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Subject: [mapserver-users] oraclespatial connection
Resent-From: Michael Smith <michael.smith at usace.army.mil<mailto:michael.smith at usace.army.mil>>
I'm using MS4W with connection to Oraclespatial. I followed the istructions on
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#oracle-10g-11g
to enable Oracle 10g support and "mapserv -v" returns a string that contains "INPUT=ORACLESPATIAL"
In mapfile I have a Layer:
LAYER
NAME PSITDATA.COMUNI
TYPE POLYGON
CONNECTIONTYPE oraclespatial
CONNECTION "UN/PW at DBSVILPU"
DATA "SHAPE FROM PSITDATA.COMUNI USING SRID 32633 VERSION 10g"
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR 0 128 128
END
END
METADATA
"wms_title" "PSITDATA.COMUNI"
#"wms_srs" "EPSG:26591"
"wms_srs" "EPSG:32633"
"wms_name" "PSITDATA.COMUNI"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_enable_request" "*" ##necessary
END
PROJECTION
"init=epsg:32633"
END
END
but I have the error:
ORA-06553: PLS-306: wrong number or types of arguments in call to 'SDO_FILTER'
. Query statement: SELECT OBJECTID_1,rownum, SHAPE FROM PSITDATA.COMUNI WHERE SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, :srid, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') = 'TRUE' . Check your data statement.
When I tried the SELECT in SQL*PLUS I had obtained:
SP2-0552: Bind variable "ORDINATES" not declared
Can you help me with the this error and with mapfile syntax?
Thank you
Michele _______________________________________________ mapserver-users mailing list mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120820/2d4f5d93/attachment.html>
