[mapserver-users] WCS Geotiff output issue
thomas bonfort
thomas.bonfort at gmail.com
Mon Aug 20 23:53:29 PDT 2012
Hi Guillaume,
The environment shouldn't be an issue here, you can test on whichever
is easiest for you. Using branch-6-2 is the way to go, but I can't
guarantee there won't be any other bugs getting in your way.
thanks,
thomas
On Mon, Aug 20, 2012 at 6:44 PM, Guillaume Loiselle
<loiselle.guillaume at gmail.com> wrote:
> Hi Thomas,
> I do not work at the same place anymore and won't be able to test on the
> same environment at all. I was on Windows XP; the closest I have now is
> Vista x64. Would a test on this system still be worth anything to you? I
> never compiled MapServer either. Can it be done on a 64-bits Windows? Should
> I use the current dev 6.2 branch (with your fix, of course) or are other
> bugs gonna get in my way?
> This should be an interesting adventure.
> Yours sincerely,
> Guillaume
> 2012/8/20 thomas bonfort <thomas.bonfort at gmail.com>
>> Guillaume,
>> I have added a fix that I believe would resolve your issue, at
>> https://github.com/mapserver/mapserver/pull/4079 . Attached is the
>> generated output with the patch applied.
>> Can you please confirm on the issue tracker that this fixes your
>> issues, and I will then make sure this gets applied in 6.2 and
>> backported to 6.0.4
>> regards,
>> thomas
>> On Mon, Nov 7, 2011 at 10:06 PM, Guillaume Loiselle
>> > Hi,
>> > Both mapfile and datasource are available in the first email I sent.
>> > http://lists.osgeo.org/pipermail/mapserver-users/2011-November/070670.html
>> > Filenames appear to be a little bit messed up but the data itself is
>> > fine. I
>> > don't know why it went so wrong.
>> > Mapfile :
>> > http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/2011102811-0001.obj
>> > Data (HDF5 format) :
>> > http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/data-0001.obj
>> > I intend to stick with 1.0.0 indeed. At least until it works... I will
>> > look
>> > up 1.1.0's details in due time.
>> > 2011/11/7 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> >> Pity that is was not just version mismatch. Could it be possible to
>> >> see
>> >> your mapfile and info about the datasource?
>> >> Stay with version 1.0.0 while testing. With version 1.1.0 you must give
>> >> EPSG:4326 coordinates in Northing-Easting order which can make things
>> >> more
>> >> complicated.
>> >> -Jukka Rahkonen-
>> >> ________________________________
>> >> Guillaume Loiselle wrote:
>> >> Hi,
>> >> I'm afraid it isn't. I didn't notice the request version I sent was a
>> >> "mixed" one but I tried Coverage on 1.0.0 and Identifier on 1.1.0 as
>> >> well
>> >> and the result was basically the same.
>> >> Here is the 1.1.0 version of the error :
>> >> <?xml version="1.0" encoding="ISO-8859-1"?>
>> >> <ows:ExceptionReport
>> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> >> xmlns:ows="http://www.opengis.net/ows/1.1" version="1.1.0"
>> >> xml:lang="en-US"
>> >> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> >> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd">
>> >> <ows:Exception exceptionCode="bbox" locator="NoApplicableCode">
>> >> <ows:ExceptionText>
>> >> msWCSGetCoverage(): WCS server error. Requested BBOX
>> >> (-178.804111261525,2802.84894277903,179.578125552223,2907.18853507175)
>> >> is
>> >> outside requested coverage BBOX (-70,45,-55,52)</ows:ExceptionText>
>> >> </ows:Exception>
>> >> </ows:ExceptionReport>
>> >> I of course spent a lot of time on the WCS server documentation page. I
>> >> saw no reference to such a problem, though. My request,
>> >> http://localhost/cgi-bin/mapserv.exe?
>> >> map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&
>> >> SERVICE=WCS&
>> >> VERSION=1.0.0&
>> >> REQUEST=GetCoverage&
>> >> COVERAGE=thelayer&
>> >> CRS=EPSG:4326&
>> >> BBOX=-67.5,48.922499263758255,-64.6875,50.736455137010665&
>> >> WIDTH=256&
>> >> HEIGHT=256&
>> >> FORMAT=GTiff
>> >> is formatted the same way the example is :
>> >> http://my.host.com/cgi-bin/mapserv?
>> >> map=mywcs.map&
>> >> SERVICE=wcs&
>> >> VERSION=1.0.0&
>> >> coverage=bathymetry&
>> >> CRS=EPSG:42304&
>> >> BBOX=-2200000,-712631,3072800,3840000&
>> >> WIDTH=3199&
>> >> HEIGHT=2833&
>> >> FORMAT=GTiff
>> >> My mapfile contains every required attribute.
>> >> Thank you.
>> >> Guillaume Loiselle
>> >> <Jukka.Rahkonen at mmmtike.fi<mailto:Jukka.Rahkonen at mmmtike.fi>>
>> >> Hi,
>> >> See examples in http://www.mapserver.org/ogc/wcs_server.html and try to
>> >> avoid mixing versions 1.0.0 and 1.1.0. Let's hope using "coverage"
>> >> instead
>> >> of "identifier" will be enough.
>> >> -Jukka Rahkonen-
>> >> Lähettäjä:
>> >> mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>
>> >> [mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>]
>> >> käyttäjän Guillaume Loiselle
>> >> [loiselle.guillaume at gmail.com<mailto:loiselle.guillaume at gmail.com>]
>> >> puolesta
>> >> Lähetetty: 7. marraskuuta 2011 21:21
>> >> Vastaanottaja:
>> >> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
>> >> Aihe: [mapserver-users] Re: WCS Geotiff output issue
>> >> Hi,
>> >> For some reason, the text part of the email didn't make it. It can be
>> >> read
>> >> below.
>> >> Attachments can still be found in the first message :
>> >> Thanks.
>> >> Guillaume Loiselle
>> >> 2011/11/4 Guillaume Loiselle
>> >> <loiselle.guillaume at gmail.com<mailto:loiselle.guillaume at gmail.com><mailto:loiselle.guillaume at gmail.com<mailto:loiselle.guillaume at gmail.com>>>
>> >> Hi,
>> >> I installed MapServer 6.0.1 on Windows XP from MS4W. I cannot give you
>> >> access to my MapServer instance but I can show you what "-v" gives me :
>> >> MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> >> SUPPORTS=PR
>> >> OJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
>> >> SUPPORTS=FRIBIDI
>> >> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> >> SUPPORTS=WFS_CLIENT
>> >> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>> >> SUPPORTS=THREADS
>> >> SUPPO
>> >> RTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> >> I am able to generate a GeoTiff file through the use of a WMS service
>> >> (see
>> >> attachment : wmsoutput.tif). The request is :
>> >> http://localhost/cgi-bin/mapserv.exe?SERVICE=WMS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&LAYERS=thelayer&VERSION=1.1.1&REQUEST=GetMap&bbox=-67.5,48.922499263758255,-64.6875,50.736455137010665&SRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
>> >> However, I cannot do so with a WCS service. I first tried with :
>> >> http://localhost/cgi-bin/mapserv.exe?SERVICE=WCS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&IDENTIFIER=thelayer&VERSION=1.0.0&REQUEST=GetCoverage&BBOX=-67.5,48.922499263758255,-64.6875,50.736455137010665&CRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
>> >> , to which I can add :
>> >> &RESPONSE_CRS=EPSG:4326
>> >> for the same result (since 4326 is my native projection). Said result
>> >> is
>> >> not a tiff file, but an error :
>> >> <?xml version='1.0' encoding="ISO-8859-1" ?>
>> >> <ServiceExceptionReport version="1.2.0"
>> >> xmlns="http://www.opengis.net/ogc"
>> >> xsi:schemaLocation="http://www.opengis.net/ogc
>> >> http://schemas.opengis.net/wcs/1.0.0/OGC-exception.xsd">
>> >> <ServiceException code="NoApplicableCode"
>> >> locator="bbox">msWCSGetCoverage(): WCS server error. Requested BBOX
>> >> (-178.835708198757,2803.05273104522,179.552848002437,2906.98474680556)
>> >> is
>> >> </ServiceException>
>> >> </ServiceExceptionReport>
>> >> This error doesn't make sense to me. Which projection is it using to
>> >> get
>> >> these silly values? Anyway, the BBOX in the request is definitely
>> >> included
>> >> in the extent... Now what if I change the Response_CRS? I would expect
>> >> it to
>> >> give me the same error, since it doesn't affect the requested BBOX.
>> >> Yet,
>> >> this time no error is produced and I obtain a tiff file (see attachment
>> >> wcsoutput.tif). The data is all wrong (0 everywhere), though. And if I
>> >> open
>> >> both WMS and WCS obtained tiffs in QuantumGIS, they appear nowhere near
>> >> each
>> >> other (for the same bbox... yes).
>> >> I attached the results of GetCapabilities and DescribeCoverage requests
>> >> as
>> >> well as the MapServer logs (modified to map logs with requests). The
>> >> data
>> >> source is an HDF5 file (see attachment : data.h5). I suspect an issue
>> >> on
>> >> MapServer's side but I would be happy if you could tell me it's all my
>> >> fault
>> >> (and how to fix it).
>> >> Oh, a last thing : it may or may not be related. I had issues with the
>> >> KML/KMZ WMS outputformats. Results for epsg:4326 and epsg:900913 were
>> >> completely different (and wrong, of course). I might open a new
>> >> discussion
>> >> on this subject at some point.
>> >> Thank you all for your help.
>> >> Guillaume Loiselle
>> >> P.S. : If you want to test, know that epsg:900913 is the same as
>> >> epsg:3857
>> >> (which is more likely to be in your epsg reference file).
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
