[mapserver-users] mapserver user can not make the shapefile data correctly show in the browser
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Aug 22 14:04:03 PDT 2012
Yang Li,
You may want to try to use a relative URL for the IMAGEURL.
Try changing it from:
IMAGEURL "/output/"
To:
IMAGEURL "output/"
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of ??
Sent: Wednesday, August 22, 2012 11:50 AM
To: mapserver-users at lists.osgeo.org
Cc: mapserver-dev at lists.osgeo.org
Subject: [mapserver-users] mapserver user can not make the shapefile data correctly show in the browser
Hello,
respected everyone,
I have a problem when using Mapserver. I just using Maperver to rend an shapefile on ubuntu 12.04. but the expect image is not correctly showing, i think there maybe some problem with my mapfile set, especially with IMAGEURL define?
I use a guide in the link :http://www.gistutor.com/mapserver/3-beginner-mapserver-tutorials/7-how-to-generate-a-simple-map-using-mapserver-and-a-shapefile.html
I assign the mapfile & template.html&start.html in my www DIR,
which is like this:
mapfiel.map:
MAP
NAME parcels_map
STATUS ON
SIZE 420 300
EXTENT 489885 5450946 490904 5451637
UNITS METERS
SHAPEPATH "shapefiles"
IMAGECOLOR 255 255 255
WEB
TEMPLATE "template.html"
IMAGEPATH "/var/www/output/"
IMAGEURL "/output/"
END
LAYER
NAME "parcel_boundaries"
DATA parcels
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "parcels_color"
COLOR 255 215 0
END
END
# end of map file
END
starrtmap.html:
<html>
<head><title>Creating a simple image using Mapserver and a Shapefile</title></head>
<body bgcolor="#FFFFFF">
<h2>Creating a simple image using Mapserver and a Shapefile</h2>
<p><hr><p>
This page simply contains a link which sends a set of instructions to the Mapserver application using a mapfile.<br />
The information stored within the mapfile tells the Mapserver application how to draw the map.<p>
<!-- The following link sends the local file structure path of the mapfile to the web location of the mapserver executable file -->
<A HREF="http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map">
Click on this link</A> to view a map generated using a Shapefile.
<p><hr><p>
</body>
</html>
template.html:
<!-- MapServer Template -->
<html>
<head><title>Simple Mapserver Template HTML Document</title></head>
<body bgcolor=#AAAAAA>
<h2>The image below was illustrated based on the instructions sent in the mapfile.</h2>
<!-- When using Mapserver with a template, the Mapserver application looks for the [img] tag within the template document to place the map -->
<img src="/[img]" border=1>
</body>
</html>
when I run the “http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map” in my address colum.
The expect map is not shown.
The page is showing content of template.html expectly, but there is only a image icon , but with no picture. And the status bar in the firefox brower is showing : conecting to output ..
I notice that in the var/www/output DIR, there have been some png file generated. And is the png containing the polygon in the shapefile. Every time when I click the “http://localhost/cgi-bin/mapserv?map=/var/www/mapfile.map” link, a new png file is generated in output DIR.
I want to know if the IMAGEURL in the mapfile is set wrongly? Why the png is genrated correctly but not showing in the browser? Any one can help me?
Yang Li
GIS Developer
P.R.China
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120822/e5e9cf04/attachment.html>
