[mapserver-users] Tile Index Issues
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Aug 22 04:59:01 PDT 2012
Hello,
You might also test your mapfile with the shp2img utility
(http://mapserver.org/utilities/shp2img.html) with the switch
"-all_debug 5" to see your errors (and report to this list).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 12-08-21 8:38 PM, Peter Mallen wrote:
> Hello All,
> I am new to map server and I am attempting to display polygon shapefiles
> using a tile index but have not been able to see any results.
> Eventually I would like to use these tiles to place images(raster) files
> on my map but I was first just testing the 'TILEINDEX' feature with
> vector data.
> All of the shapefiles being referenced in my index shapefile are in the
> same folder.
> Also, in my index shapefile I have the following two shapefiles
> referenced under the 'location' column:
> \ms4w\Apache\htdocs\map.data\Guatemala_Cities.shp
> \ms4w\Apache\htdocs\map.data\Bolivian_Cities.shp
> The following page was used as a reference for creating my map file:
> http://mapserver.org/utilities/tile4ms.html
> Any help on this would be great.
> Thank You,
> Peter Mallen
