[mapserver-users] No transparency for layer
Henrique Rennó
henrique.renno at gmail.com
Sat Aug 25 15:54:44 PDT 2012
Hello,
I'm using a map file with "TRANSPARENT ON" and "IMAGECOLOR 255 255 255" in
order to make white becomes transparent for layers and it's working. The
problem is that I have one layer for roads where background is white and
becomes transparent but another layer for rivers where rivers are white, so
they are not displayed. Is there a way to indicate that for the rivers'
layer I don't want transparency to be applied? Both geometries are loaded
from a postgis database which I imported from shapefiles and the shapefiles
were not made by me. The strange thing is that if I set a color for the
rivers' layer within a style then the "background" is set to that color,
but I thought the rivers would be colored. That means the geometry is set
for everything except the rivers? That's strange.
Thanks in advance
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120825/dbbd0ffd/attachment.html>
