[mapserver-users] No transparency for layer
Henrique Rennó
henrique.renno at gmail.com
Sat Aug 25 16:51:33 PDT 2012
Just had another problem. It seems that point geometry from a postgis
database are not being displayed. What could be?
2012/8/25 Henrique Rennó <henrique.renno at gmail.com>
> Hello,
> I'm using a map file with "TRANSPARENT ON" and "IMAGECOLOR 255 255 255" in
> order to make white becomes transparent for layers and it's working. The
> problem is that I have one layer for roads where background is white and
> becomes transparent but another layer for rivers where rivers are white, so
> they are not displayed. Is there a way to indicate that for the rivers'
> layer I don't want transparency to be applied? Both geometries are loaded
> from a postgis database which I imported from shapefiles and the shapefiles
> were not made by me. The strange thing is that if I set a color for the
> rivers' layer within a style then the "background" is set to that color,
> but I thought the rivers would be colored. That means the geometry is set
> for everything except the rivers? That's strange.
> Thanks in advance
> Henrique
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120825/adda40a6/attachment.html>
