[mapserver-users] No transparency for layer
Henrique Rennó
henrique.renno at gmail.com
Sat Aug 25 17:13:50 PDT 2012
Searching on google, I found that other people had the same problems with
points, but I have set symbol to "circle" and increased size with no
success.
2012/8/25 Henrique Rennó <henrique.renno at gmail.com>
> Just had another problem. It seems that point geometry from a postgis
> database are not being displayed. What could be?
>> Hello,
>> I'm using a map file with "TRANSPARENT ON" and "IMAGECOLOR 255 255 255"
>> in order to make white becomes transparent for layers and it's working. The
>> problem is that I have one layer for roads where background is white and
>> becomes transparent but another layer for rivers where rivers are white, so
>> they are not displayed. Is there a way to indicate that for the rivers'
>> layer I don't want transparency to be applied? Both geometries are loaded
>> from a postgis database which I imported from shapefiles and the shapefiles
>> were not made by me. The strange thing is that if I set a color for the
>> rivers' layer within a style then the "background" is set to that color,
>> but I thought the rivers would be colored. That means the geometry is set
>> for everything except the rivers? That's strange.
>> Thanks in advance
>> Henrique
> Henrique
Henrique
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120825/d9683e2d/attachment.html>
